Why do bar magnets have zero velocity after collision?
In summary, the question's answer is that the momentum of the system is conserved, and that the final speed of the magnets after the collision is equal to the initial speed of the magnets before the collision.
TomK
69
ENGAA 2018 (Section 2, Question 4)
Conservation of momentum
I don't understand the reasoning of this question's answer. The answer is velocity = 0 (option A).
A while ago, I was told that, since the magnets were held at-rest (before being let go), they must have no velocity after the collision. What about the velocity which they had just before the collision? It is stated that the larger magnet has velocity v.
If you try to use conservation of momentum, you end-up with too-many unknown variables, meaning you must make an assumption about conservation of energy to get an answer.
The total momentum of the system comprised of the two magnets is conserved! Since both magnets start from rest (both have zero initial velocity), what is the initial total momentum of the system?
Once they have coalesced, the total momentum of the system after the collision is ##(m_1 + m_2)V##, if ##V## is the final velocity. What must ##V## be?
Why do we use the initial velocities of zero when you could use the velocity immediately before the collision (i.e. X has velocity v)? How do you know which to use? I understand the momentum calculation, but I don't understand why you don't use the velocities right before the collision.
For this scenario the momentum of the system is conserved for all ##t\geq 0##, so the total momentum right when you release them, 0, will be the same as right before they collide, 0, and will also be the same as after the collision, 0.
If you weren't given that they both start from rest, they you could not deduce the total momentum of the system given only the speed of magnet X before the collision, because you don't know the speed of magnet Y! In which case you wouldn't be able to work out the final speed.
The question setter is just trying to throw you off by giving you unnecessary information, don't be misled!
That makes more sense now. Thank you.
Likes etotheipi
Related to Why do bar magnets have zero velocity after collision?
1. Why do bar magnets have zero velocity after collision?
Bar magnets have zero velocity after collision because of the conservation of momentum. This law states that the total momentum of a closed system remains constant, meaning that the total momentum before the collision must equal the total momentum after the collision. Since bar magnets are a closed system, their total momentum must remain constant, resulting in zero velocity after collision.
2. Does the shape of the bar magnet affect its velocity after collision?
No, the shape of the bar magnet does not affect its velocity after collision. As long as the bar magnets are a closed system, their total momentum will remain constant, regardless of their shape.
3. Can bar magnets have non-zero velocity after collision?
Yes, bar magnets can have non-zero velocity after collision if there is an external force acting on them. In this case, the conservation of momentum law would not apply, and the bar magnets could have different velocities after the collision.
4. Why is it important for bar magnets to have zero velocity after collision?
It is important for bar magnets to have zero velocity after collision because it ensures that the total momentum of the system remains constant. This is a fundamental law in physics and helps to explain and predict the behavior of objects in motion.
5. Can the velocity of bar magnets after collision be calculated?
Yes, the velocity of bar magnets after collision can be calculated using the conservation of momentum law. By knowing the mass and initial velocity of the bar magnets, as well as the type of collision (elastic or inelastic), the final velocity of the bar magnets can be determined.
