Why does dropped ballast continue ascending before falling?
carlitos_30
A balloon is ascending at an speed of 13 m/s. At 300 m from the ground a ballast is drop from the balloon. Find the maximum height the ballast reach.
My doubt is: When the ballast is drop ¿it starts falling inmediately?. The solution of the problem implies that the ballast keep ascending for 8,6 m.
Thanks.
Thanks.
While the balloon is ascending, everything in the balloon is ascending at the same velocity. It's no different if you pick up a rock and throw it straight up at 13 m/s.
It takes gravity a finite duration to arrest the upward motion and bring the velocity to zero, before things begin to fall back to the ground.
An observer in the ground would see the ballast fall inmediately, I mean he wouldn't see the ballast ascending for 8,6 meters. That's what I imagine. What's wrong with my imagination?
What about a ball dropped from a car moving at 13 m/s?
If you're watching from the side of the road what speed will the ball be traveling as soon as it's dropped? Will it s stop where it lands? Or continue bouncing down the road?
How do you know what someone else sees?
If you throw a rock straight up at 13 m/s, does the rock stop immediately once it leaves your hand and drop to the ground?
You can imagine many different things, some real, some impossible. We deal with science at PF, not your imagination.
This is a great example. Thanks.
Sure not. The observer in the ground just can't note the ballast keep ascending because of the distance and he has no reference to compare the movement (the clouds are not good ones). An observer at the same level when the ballast is drop, would see the ballast ascending a little.
