Why Does ds^2 Equal 0 in Metrics?
  • Context: Undergrad
  • Thread starter Thread starter Arman777
    Metric
10 replies · 3K views
Arman777
Insights Author
In FLWR metric or in Minkowski metric or in any general metric can we say that ##ds^2=0## cause speed of light should be constant to all observers ?
Or there's another reason ?
What do you mean? What ##ds^2## is depends on the world-line you are considering. ##ds^2 = 0## corresponds to a light-like curve. This is a coordinate independent statement and it will be true for the light-like curve regardless of the coordinate system you use.
In FLRW metric when we measure the redshift we assume ##ds^2=0##. Like also in minkowski metric ##ds^2=0## cause only in that case we can get c=dx/dt.
Probably I should add to the question why for a light ##ds^2=0##...
This is not a measurement of redshift. It is a computation of the redshift based on the FLRW universe. Studying light, it is quite clear that we must use a light-like geodesics.
Light is massless and moves along null geodesics.
Hmm I see, I ll do more research on light-like geodesic case.
I haven't seen it yet so I was confused about the reason. I guess I can understand why we use ##ds^2=0##.
Arman777 said:
In FLRW metric when we measure the redshift we assume ds2=0ds2=0ds^2=0.
The redshift you are talking about is for light. Light travels on null geodesics. Therefore ##ds^2=0##. It is not a general statement about the metric, it is a specific statement about light.
Arman777 said:
Like also in minkowski metric ds2=0ds2=0ds^2=0 cause only in that case we can get c=dx/dt.
Same thing here. For light ##ds^2=0## for the reason you gave. But for massive objects ##ds^2<0## and for hypothetical tachyons ##ds^2>0##.
Arman777 said:
Probably I should add to the question why for a light ds2=0ds2=0ds^2=0...
If you write down the metric, set ##ds^2=0##, then what are you left with? The equation of a sphere of radius ##ct##. This is something traveling at c in all directions, which is the second postulate. Therefore, ##ds^2=0## for light is the mathematical statement of the second postulate.
I think it should be qualified that whether ##ds^2 > 0## or ##ds^2 < 0## for time-like world lines depends on the sign convention for the metric. Mathematicians and GR people generally prefer ##ds^2 < 0## while particle physicists prefer ##ds^2 > 0##. Always check which convention is being used in the particular text. Of course, this does not affect ##ds^2 = 0## for null world lines.
Orodruin said:
I think it should be qualified that whether ds2>0ds2>0ds^2 > 0 or ds2<0ds2<0ds^2 < 0 for time-like world lines depends on the sign convention for the metric.
Yes, good point. My preferred convention is to write ##ds^2## when I am using the (-+++) convention and to write ##d\tau^2## when I am using the (+---) convention
Yes I tried to mean that, as I understood from your post for light ##ds^2=0##. But Is this true for all of the metrics ?
In example For Minkowski metric we are working on light rays then ##ds^2=0##, in FLRW metric , we are working on light then ##ds^2=0## etc. ?
Or there could be a metric where we can't set ##ds^2=0## for light ?
Dale said:
If you write down the metric, set ds2=0ds2=0ds^2=0, then what are you left with? The equation of a sphere of radius ctctct. This is something traveling at c in all directions, which is the second postulate. Therefore, ds2=0ds2=0ds^2=0 for light is the mathematical statement of the second postulate.
I see, thanks
Also,
I understand it now
Yes, it is true for all metrics and all spacetimes
