Why does mass double when wind speed increases from 60 to 120 mph?
6 replies · 3K views
Shaye
The arrival of a hurricane is predicted with wind speeds of 120 mph (miles per hour). The force exerted by a 60 mph gale on the sides of a train locomotive has been measured and found to be F. Will the hurricane forces on the same locomotive be:
1. The same as F
2. Twice as large as F
3. Three times as large as F
4. Four times as large as F
F=Δp/Δt and Δp = Δ(mv)
The marker wrote that the answer is 4 and it's because m and v double. I don't understand how m doubles??
Can you find an expression for m in terms of the air density and the wind speed?
The only thing I can think of is p=m/v and m=pv and ke = 1/2(pv)*v^2...but I'm still at a loss
So, you now have impulse = mv and ##m = \rho v A## ... (you need the area to make a mass/time out of the density.
That confused me. p is usually used for momentum and lowercase v for velocity, leading to equations like p=mv. So I think you mean ##m=\rho V##, V being volume. But then you have ##ke = 1/2(pv)*v^2##, which uses v for velocity and volume, so write ##KE = 1/2(\rho V)*v^2##.
Next is to consider what volume of air impinges upon the train in time t.
Oh yes, using v instead of V for volume clearly confused me too to see what I expected to see. @Shaye Never use the same letter for different quantities in the same problem.
