Why Does MCNP5 Behave Differently Across Operating Systems?
  • Thread starter Thread starter junaidarshad
    Loops Mcnp5 Stuck
The discussion centers on the behavior of MCNP5 simulations across different operating systems, specifically comparing performance on a CentOS cluster versus Windows. Participants explore issues related to simulations getting stuck in loops and the implications of parallel processing in MCNP5.
  • Technical explanation, Debate/contested
  • One participant reports that MCNP5 is stuck in a loop during simulations on CentOS 6.5 with mpich2-1.4.1p, while the same simulations run successfully on Windows with mpich-1.2.4.
  • Another participant confirms experiencing the same issue with MCNP5 getting stuck in loops and inquires if a solution has been found.
  • A participant suggests that the issue may be related to how MCNP divides problems for parallel processing, indicating that only one process was stuck while others completed their tasks.
  • One participant mentions that they allowed the simulation to run for an extended period, which eventually resolved the problem, although another participant states that their simulation did not return to normal even after a long wait.
Participants generally agree that the issue involves MCNP5's handling of parallel processing, but there is no consensus on the effectiveness of letting the simulation run longer as a solution, as experiences vary.
Participants have not provided specific details on the configurations or parameters used in their simulations, and there may be missing assumptions regarding the nature of the simulations and the environments in which they are run.
junaidarshad
I recently installed MCNP5 on rocks cluster running centOS 6.5, with mpich2-1.4.1p.
While running simulations, MNCP5 is stuck in loop in 2 of the simulations.
When I tried to perform one of the stuck simulations on windows with mpich-1.2.4, it didn't stuck. Can anyone guide me why MNCP5 is behaving differently on different operating systems.
Regards,
Regards,
I got the error too, mcnp5 stucked at 2 of simulations loop.
Did you solved it ?
Did you solved it ?
There was nothing to solve. The problem was because of the way MCNP divides the problem for parallel solution. Only one of the Processes was stuck, while rest of the processes had done their job. I let it run and after some time it solved the problem.
I let it run but it can't return normal after a very long time.
9K
32K
