Why does squaring a false equation make it true?
20 replies · 3K views
mark2142
“We know extraneous solutions may get introduced when we square the two sides of an equation because the operation of squaring can turn a false equation into true one”.
##2x-1= -\sqrt{2-x}##
Does this mean for x=1 , ##2(1)-1= -\sqrt{2-1}## is false. x=1 is not a solution.
But as we square the above equation , ##(2(1)-1)^2=(-\sqrt{2-1})^2## , false equation becomes true. So now x=1 is solution to the new equation ?
(Here is the paragraph attached) from book James Stewart.
This is a common mistake. It is perfectly valid to square the equation. But what does that mean?
2x-1=-\sqrt{2-x}\;\Longrightarrow \; (2x-1)^2=4x^2-4x+1=2-x \;\Longrightarrow \;4x^2-3x-1=(x-1)(4x+1)=0
and ##x=1## is a possible solution. The misconception, however, is that we deduced a necessary condition by every single step. The full conclusion reads ##x\in \left\{1, -\frac{1}{4}\right\}.## This is necessary. It is NOT sufficient! Squaring prevents us from reversing the steps to the left, so we have only a necessary, no sufficient solution.
We always have to make sure, that the solutions, here ##1## and ##-1/4## are indeed solutions. We have to put it into our first equation so that we find:
\begin{align*}
2\cdot 1-1&=1\neq -1=-\sqrt{2-1}\\
2\cdot (-1/4)-1&=-3/2= -\sqrt{2-(-1/4)}=-\sqrt{2.25}=-1.5
\end{align*}
and only ##x=-1/4## is also a sufficient condition for our primary equation to hold.
Yes it is. It's just that the new equation is not equivalent to the old one !
[edit]typed far less than Fresh but took a lot longer to do it :nb)
I don’t understand. I am asking how are extraneous solutions introduced? Does anyone get what I am saying?
If you have ##x=1## as equation, then it is ##x-1=0.## Building
(x-1)\cdot (x-a_1)\cdot \ldots\cdot(x-a_n)=0
gets you as many solutions as you want.
I think I do. And I surely know what you are asking:
And the answer is 'Yes it is'.
Do you understand your own question and the affirmative answer ?
Now you have another question
which is answered in the homework statement already.
How can we help ?
And here is the homework statement @BvU referred to:
A better way to say the last part is that the operation of squaring changes the degree of the equation we're trying to solve to a higher power, which means that it will have additional solutions that aren't solutions of the lower-degree equation.
Very simple example:
##x = -2## -- solution set {-2}
Square both sides to get
##x^2 = 4 \Rightarrow x^2 - 4 = 0 \Rightarrow (x - 2)(x + 2) = 0## -- solution set {-2, 2}
mark2142 said:
Homework Statement: “We know extraneous solutions may get introduced when we square the two sides of an equation because the operation of squaring can turn a false equation into true one”.
Relevant Equations: ##2x-1= -\sqrt{2-x}##
Try a simpler example.
##x=1##
##x^2=1##
##x=1## and ##-1##
So yes, squaring introduces a new potential solution that needs to be tested. In this case ##x=-1## is not a solution because ##-1≠1##.
Is this what you are asking?
Reply
##x=1##
##x^2=1##
##x=1## and ##-1##
Let me give it a try. Lets take ##x=-1##. I added -ve sign to make it analogous to our original equation ##2x-1=-\sqrt {2- x}##
##2x-1=-\sqrt {2- x}## equivalent to ##x=-1=-\sqrt 1##
(Here ##2x-1## expression is ##x## and ##2-x## expression is ##1##)
Solution: x=-1/4 and x=-1
Squaring both sides-
##(2x-1)^2=2- x## equivalent to ##x^2=1##
Factoring the left side:
##(x-1)(4x+1)=0## equivalent to ##(x-1)(x+1)=0##
Solutions: ##x=1,-1/4## and ##x=\pm1##
@mark2142
Yes that is right.
In my simple example the ## x=-1 ## extraneous solution is introduced when we square both sides of ## x=1 ##.
And in your case the ## x=1 ## extraneous solution is introduced when we square both sides of ## 2x-1=-\sqrt{2-x} ##.
YouAreAwesome said:
@mark2142
Yes that is right.
Please verify each step so that I am sure I understood it in depth and not superficially.
I'm not quite sure what you mean by in depth, and maybe someone higher up in the mathematics food chain can show this more precisely but I would say:
If ## x=a ## then ## a ## is the only solution.
However, if ## (x)^2=(a)^2 ## then both ## x=a ## and ## x=-a ## are solutions.
I don't know if this will help, but ## y=ax ## is a linear function i.e. a straight line where for every ## x ## there exists exactly one ## y ## and vice versa (one to one). While for the function ## y=\sqrt{(ax)^2}## for every ## x ## there exists exactly one ## y ## but for every ## y ## there exists exactly two value of ## x ## (many to one).
I mean my all lines are right especially where I said ##2x-1## can be taken as ##x## and ##2-x## is ##1##?
Actually I was searching for you, person whom I can understand because they are talking in the same language as my current maths book. So it becomes very easy to follow up. I don't understand much when people talk in high level language. You know what that means. HaHA :)
Reply
Yes, to me post #9 looked fine assuming I read it correctly. The part that was a little unclear was in your first solution ## x=-1/4 ## and ## x=-1 ##. I read this to mean that the ## x=-1 ## solution is in regard to my example and not meant to be a solution to your original equation.
Haha! Yes, I understand what you mean 😀.
Reply
You want it simple ?
##x=-x## is an equation with one solution: ##x=0##.
Squaring both sides gives you ##x^2 = x^2## which is a tautology (an equation which is satisfied for all ##x##).
So yes, squaring on both sides introduces extraneous solutions.
:wink:
Reply
:wink:
I like when I am able to see in those complicated equations what simple things are going on in terms of ##x## and ##y##.
By the way in post #9 I factored eqn ##1## (##(2x-1)^2=2- x##)by splitting the middle term and eqn ##2## (##x^2=1##) by the factoring formula ##A^2-B^2##. I don't think that will make any difference how we factor.
Reply
Is it possible to find the solution of ##2x-1=-\sqrt {2- x}## in the start without squaring?
I mean we know the solution of ##x=-1## is ##x=-1## at the start. So it would be good if we declare the solution of the original equation in the beginning if we are doing analogies.
I thought you might be able to do this:
## 0=2x - 1 + \sqrt{2-x}##
## 0=(2x - 1 + \sqrt{2-x})(2x - 1 - \sqrt{2-x}) ##
## 0=4x^2 - 4x + 1 - (2-x) ##
## 0=4x^2 - 3x - 1 ##
## 0=(x-1)(4x+1) ##
But by multiplying both sides by the conjugate we are also adding extraneous solutions as it is essentially squaring.
So as far as I know, we have to solve the equation by squaring, followed by a "test and check" to see if what we found were indeed solutions.
In a more general sense, systems of equations, the equations, allow for some operations on them that preserve solutions, while other operations on them don't preserve the solution set. You may compare to systems of linear equations, where there are just 3 operations preserve solutions: exchanging rows, adding a multiple of a row to another row, and multiplying both sides of an equation by the same non-zero number. The operations that preserve solutions form a group, so, as Fresh pointed out, any such property must be reversible, as each element in a group is invertible.
