Why fish under water see a circle surrounded by darkness
  • Thread starter Thread starter Drezzan
    Circle Water
The discussion revolves around the optical phenomenon experienced by fish when looking up at the surface of a pond. The original poster describes a scenario where a fish perceives a cone of light surrounded by darkness, prompting questions about the underlying physics and calculations related to the cone angle.
  • The original poster attempts to explain the phenomenon using concepts such as Snell's law and critical angles, while questioning the role of total internal reflection. Participants explore the implications of light behavior at the water's surface and the nature of the perceived darkness outside the cone of light.
Participants are actively engaging with the problem, with some providing insights into the visual experience of being underwater. There is a recognition of the complexity of the situation, and the discussion is evolving with various interpretations being explored.
The original poster notes the absence of specific data and equations, which may limit the depth of analysis. There is also an emphasis on understanding the conditions under which light behaves differently at the water's surface.
Drezzan
A fish looking straight up to the surface of a pond receives a cone of light filled with images. This bright field is surrounded by darkness. Explain what is happening and compute the cone angle.
No given data but ##n_w=1.33##
No give equations but I anticipate Snell's law and maybe the critical angle equations will come into play.My attempts were to explain this by the light rays being bent in a way that the higher ##\theta_i## completely miss the fish eye. However that would not create the dark halo effect the problem states. I have looked for an answer using total internal reflection but that requires the light to be passing from a dense medium to a less dense. Total external reflection also has the stipulation the that the frequency of the light must be much greater than the resonant frequency of the atoms, and this would cause no light transmitted correct? Please help me understand this question a bit better. Thank you !
"I have looked for an answer using total internal reflection but that requires the light to be passing from a dense medium to a less dense"
So what would this look like to you if you were underwater? Assume that there is only darkness from the direction of the water and all the light is coming from above the water.
outside of that cone, there is reflection only of the "darkness" from below.
Oh wow thank you I guess I was over thinking this.
9K
