ioannisakousoulakos
- 7
A debate has started where the accelerometers
when stacic on the ground produce real acceleration towards the surface or propper acceleration (α) / free falling ( Geodesic ) . Lets figure out what the GR says about all this .
Sir I 100% agree with you and maybe I sould differentiate the term proper from the very beggining , so there is no real acceleration towards the sky and the value taken is because the ground exerts a mechanical normal force that prevents the device from entering free fall as its path deviates from a geodesic.Ibix said:To repeat what everyone else has said, it is the proper acceleration that is the direct observable. This is the lesson you are supposed to have taken from Einstein's lift thought experiment. If you are in a closed box (such as a lift) there is no local way to distinguish between the cases that the lift is at rest on the surface of a planet or in a rocket in deep space under thrust. In both cases you can measure identical weight from a given mass. Nor is there any way to distinguish between free falling above an (airless) planet and floating inertially in deep space. And in any of these cases you may consider yourself to be at rest or undergoing coordinate acceleration.
The only physically meaningful quantity here is the proper acceleration.
