Why (R/I)-modules require am = 0 for all a in I
  • Level: Undergrad
  • Thread starter Math Amateur
    Example Section
7 replies · 3K views · last reply
Math Amateur
MHB
I am reading Dummit and Foote's book: "Abstract Algebra" (Third Edition) ...
I am currently studying Chapter 10: Introduction to Module Theory ... ...
I need some help with an aspect of Example (5) of Section 10.1 Basic Definitions and Examples ... ...
Example (5) reads as follows:
I do not fully understand this example and hence need someone to demonstrate (explicitly and completely) why it is necessary for ##am = 0## for all ##a \in I## and all ##m \in M## for us to be able to make ##M## into an ##(R/I)##-module. ...
Help will be much appreciated ..
Peter
Hey Peter.
It is needed to make sure that the operation that turns ##M## in a ##R/I## module is well defined, i.e., one must show that what is written down, is a (well-defined) function.
This is routine work.
Indeed, suppose that ##(r_1 + I, m_1) = (r_2 +I,m_2)##, then ##m_1 = m_2## and ##r_1 + I = r_2 + I##.
The latter one implies that ##r_1 - r_2 \in I##, and by assumption ##m_1(r_1 - r_2) = 0##, so that ##m_1r_1 = m_1r_2 = m_2r_2## and hence the function is well defined.
Hope this helps.
Thanks Math_QED ...
BUT ... I need a clarification ...
Dummit and Foote write elements of the ##R/I##-module as ##m## ... what are the elements of the form ##(m_1, r_1 + I)##?
I can understand an element of the form ##(r+I)m## belongs to the left ##R/I##-module ... but how do we get an element of the form ##(m_1, r_1 + I)##?
Can you help ...
Sorry if i am being slow ...
Peter***EDIT***
Did you mean ##(m_1, r_1 + I) \equiv m_1(r_1 + I)## ... that is an element from a right ##R/I##-module ...?
Math Amateur said:
Thanks Math_QED ...
Can you help ...
Peter
Sorry, I wrote the module as a right module, while the book writes it as a left module. (I edited my previous post and changed the order in the tupels) However, this doesn't change your question of course. The operation in the R/I module M is:
##R/I \times M \to M: (r+I,m) \mapsto rm##
And for convenience we write this as ##(r+I)m = rm##
But who says that what I wrote down is a function? This needs to be checked. I.e., one must check that for every element ##(r+I,m) \in R/I \times M##, there is precisely one output associated with this input (see uniqueness of image in the definition of function).
That's what I proved: Hope it is clear now.
If you like an analogy that you have already encountered (probably), think about the function ##\phi: G/\ker f \to f(G): g + \ker f \mapsto f(g)## which you already encountered in the first isomorphism theorem of groups. We must also prove that this function is well defined.
Thanks Math_QED ...
Yes ... clear now ... post above is most helpful ...
Peter
Hi Math_QED ...
Another question that you may be able to help with ... I am puzzled about the definition and nature of the "multiplications" involved in the equation
##(r+I)m = rm## ... ... ... ... ... (1)It seems to me that there are two multiplications involved and I am not sure how they are defined ... indeed suppose the two multiplications are ##\star## and ##\circ## ... ... then, (1) becomes##(r+I) \star m = r \circ m##But how are ##\star## and ##\circ## defined ... where do they come from ... what is their nature ,,,Can you help ... ...
Math Amateur said:
Hi Math_QED ...
You are right: the multiplication in the R/I module is build using the multiplication in the R-module! This is something that is done a lot in mathematics: extending known structures to other structures.
This thing also happens for example when we define an operation on the sets of cosets ##g+N## where ##g## is an element of a group ##G## and ##N## is a normal subgroup. We define ##(gN)\circ(hN) = (g.h)N## where ##\circ## is the operation in the quotient group, ##.## the operation in the group ##G##. This also gives another example of an addition where it is not clear whether this is well defined. Turns out that the addition I wrote down here makes sense if and only if ##N## is a normal subgroup.
To give a concrete answer to your question: the operation ##\circ## in your case is given. It is just an operation on the R-module ##M##. The other one is defined, in terms of ##\circ##, via the formula you wrote down.
Thanks Math_QED ...
Very much appreciate all your help on the above issues ...
Peter
