Why use psi instead of just pound?
  • Thread starter Thread starter david90
    Psi
Pressure in a compressor is measured in PSI, which stands for pounds per square inch, to account for the relationship between force and area. The formula P = F/A illustrates that pressure changes with varying nozzle sizes while keeping total force constant. If a nozzle's area increases, the pressure decreases proportionally, as seen in the example of a 10 sq in nozzle reducing pressure from 10 PSI to 1 PSI. This distinction is crucial because pressure reflects the intensity of force applied over a specific area, rather than just the total force itself. Understanding this concept is essential for effectively managing compressor output and performance.
david90
Why does the pressure in a compressor have a unit PSI instead pound? If the pressure of a compressor is 10 PSI, would a 10 sq in nozzle cause the pressure to drop to 1 psi?
It depends on what the total force is. If the total force is 10 pounds and you went from a 1 sq. in. nozzle to a 10 sq. in nozzle, the psi would then drop to 1. This assumes the total force is unchanged.
Yes, pounds is a force in this context and PSI is pounds per square inch, which is called a pressure, or force per unit area. The formula for this is P = F/A and therefore PSI = (Pounds)/(Inch^2). The reason it is PSI instead of just pounds is because of how the pressure changes with respect to the amount of area the force is applied over. Imagine your body weight (a force) being applied over both feet (an area), or while standing on one foot (a smaller area). If, for example, you were standing on a thin piece of plywood or something that could barely hold your weight with both feet, it's quite possible that transitioning to standing on one foot would be enough to snap the board due to the increased pressure--double the pressure to be exact assuming each foot has the same area.
If you were using a compressor, then as mathman pretty much said, the force would almost certainly be what stays constant and the pressure would therefore decrease if you increased the nozzle area. Increase the nozzle area by 10 times, you reduce the pressure by 10 times, and that relationship is implicit in the math of the P = F/A formula.
In a lot of instances, the pressure stays constant while the force changes depending on the area, so it's appropriate to have a unit describing this phenomenon.
Right, and the OP was describing a compressor, in which output is controlled to constant pressure, not constant force.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 27 ·
