brotherbobby
- 806
- 178
- Homework Statement
- Two ships A and B begin at the same time from their respective points 4 kms apart along the ##y## axis with speeds 3 km/h and 1 km/h (uniformly) respectively, as shown in the figure below. The motion of ship B is parallel to the ##x## axis while that of A is at an angle of ##60^{\circ}## to the ##x## axis. ##\textbf{Will the two ships collide at point P}?##
- Relevant Equations
- For unaccelerated motion, distance travelled ##d = v_0 t##, where ##v_0## is the uniform speed. Also, in a right angled triangle, ##\cos \theta = \frac{\text{adjacent}}{\text{hypotenuse}}##.
There are two ways to solve. My problem is, when I apply the two, I end up with a contradiction.
Method 1 : Conclusion - Ships will not collide .
Imagine the ships collide after a time ##t##.
Since they both start at the same time, the distances traveled by them would be ##3t## (A) and ##t## (B), respectively. (I have shown the two distances in the diagram, in terms of ##t##).
Using parallel-line and angles, we see that ##\angle BPA = 60^{\circ}##. Thus if we take the cosine of the angle using trigonemetrical ratios of a right angled triangle, we have ##\cos 60^{\circ} = \frac{t}{3t} = \frac{1}{3}##!
We know that ##\cos 60^{\circ} = \frac{1}{2}##, hence it's clear that two two ships will not collide .Method 2 : Conclusion - Ships will collide.
In the right angled ##\triangle ABP##, using the Pythagorean theorem, we have ##(3t)^2 = t^2 + 4^2 \Rightarrow 9t^2 = t^2 + 16 \Rightarrow 8t^2 = 16 \Rightarrow t^2 = 2 \Rightarrow t = \sqrt{2}\; \text{hr} \approx 85 \text{minutes}## .
Hence the two ships will collide after a time of 85 minutes from start.
Contradiction
One possible way out is to note that nowhere in my second solution did I consider the fact that Ship A was moving at an angle of 60 degrees to the horizontal. What I did show was that with the speeds as given, the two ships can collide after the given time (85 minutes). If that was to happen, then the angle at which Ship A should move would be ##\cos^{-1} \frac{t}{3t} = \cos^{-1} \frac{1}{3} = 70.5^{\circ}##. It becomes a different problem really : Given the speeds of 1 and 3 km/h, calculate the angle at which ship A should move in order that they collide.
Am I right? When I drew the relative velocity of B with respect to A (##\vec v_{BA}##), I found that it was pointing away from A, clearly showing that ship B would not be moving in A's direction and that no collision would take place.
