Work done drawing a compound bow from force-distance graph
6 replies · 7K views
Angela_vaal
A compound bow in archery allows the user to hold the bowstring at full draw with considerably less force than the maximum force exerted by the string. The draw force as a function of the string position x for a particular compound bow is shown in (Figure 1) .
Part A
How much work does the archer do on the bow in order to draw the string from x=0 to x=0.60m?
Express your answer to three significant figures and include appropriate units.
area= work
total work=sum of all areas
(.2m x 350 N)/2 + (.3m x 350 N) + (.1m x 250 N)/2 = 152.5J
153J for three sig figs.[/B]
Apparently the answer is wrong, but I do not know what I did wrong? I found the area of the two triangles, and the rectangle in the three equations above.
phinds said:
But the area is NOT "two triangles and a rectangle". Do you see why I say that?
No I do not. Is it because from .5m to .6m it is not a complete triangle?
Your thread title is too general. I've modified it to better identify the type of problem.
You've missed a bit of the area under the curve. Take a closer look at the region of the smaller triangle: what's it "sitting" on?edit: Ah. Phinds got in there before me!
the smaller triangle is sitting on a small rectangle between .5m to .6m?
Right.
That was tricky, but I got it now. Thanks!
