Write with at least one less abs value symbol
  • Thread starter Thread starter Saladsamurai
    Symbol Value
11 replies · 3K views
Saladsamurai
Here we go. Write the following with at least one less absolute value symbol:
(ii) |(|a+b| - |a| - |b|)|
(iii) |(|a + b| + |c| - |a + b + c|)|
(iv) |x2 - 2xy + y2|
12 Properties of Numbers.
Let's just look at (ii) for now since I am getting all flustered with it:
There are 2 potential abs value symbols that could be dealt with:
1) I could try to show that the quantity |a+b| - |a| - |b| ≥ 0 and the outermost symbols could be dropped.
OR
2) Try to show that -|a|-|b| = -|a+b| and re-write the original expression as |(|a+b| - |a + b|)|
Either way is a pain. It seems like there are so many 'cases' to test. Am I correct in saying that I would need to test all of the following cases?
I. a = b > 0
II. 0 < b < a
III. 0 < a < b
IV. a < 0 < b where |a| < |b|
V. b < 0 < a where |b| < |a|
VI. a < 0 < b where |b| < |a|
VII. b < 0 < a where |a| < |b|
VIII. a = b = 0
IX. a = b < 0
Am I overkilling here? Are any of these equivalent? I am thinking "no" because its subtraction involved ...
:mad:
OR
I. a = b > 0
II. 0 < b < a
III. 0 < a < b
VIII. a = b = 0
IX. a = b < 0
:mad:
For (ii) What does the triangle inequality tell you about how |a+b| and |a|+|b| are related?
For (iv) Factor x2 - 2xy + y2 .
From the triangle inequality: |a+b| ≥ |a| + |b| → |a+b| -|a| - |b| ≥ 0 ... jeesh...nice catch SammyS!
EDIT: oof! that's backwards! Now I'm screwed. I need sleep. Back in morning!
For (iv)
I see that it is |(x+y)(x-y)| but I am not sure what to do with that? Again there are many cases to test, right?
I was originally thinking that since x2 and y2 are always > 0, then I would want to try to show that: x2 + y2 ≥ 2xy for all x,y.
Then I suppose it means that
|a+b| -|a| - |b| ≤ 0​
That should still allow you to remove one pair of | | symbols.
For (iv)
Not quite right!
(x+y)(x-y) = x2 - y2
Try again.
For (iii): Try the triangle inequality here too.
So I have come back to this one finally: I am still unsure if part (ii) ... I think I am missing the obvious.
(ii) ##|(|a+b| - |a| - |b|)|##
From the triangle inequality I have that ##|a+b|\le|a|+|b|\implies |a+b| - |a| - |b|\le 0## so for sure I cannot remove the outer most abs value signs. This means that I am looking at removing (at least) one of the inner sets. As a guess, I am choosing to remove the signs around ##|a+b|## which means that I need to show that for any values a,b, that ##|a+b| - |a| - |b| = a+b - |a| - |b|.##
But I don't know if this is correct. I am pretty sure it is not.
Are you really sure? What is ##|x|## if ##x\le 0##?
I'm sorry LCKurtz, I don't think I understand what you're asking? |x|=-x if x≤0. But what is your point :redface:?
Think about what you said above which I colored red. What if that is x?
Hi LKCurtz! I don't think I had enough foresight to realize that I could remove an abs value sign and rearrange the expression :redface:. How about this?
##|(|a+b|-|a|-|b|)|=|b|+|a|-|a+b|##
Yes. That's the idea.
Just to finish up:
(iii) ##|(|a + b| + |c| - |a + b + c|)| = |a + b| + |c| - |a + b + c|##
since ##|a + b + c| \le |a + b| + |c|## by triangle inequality.
and
(iv) ##|x^2 - 2xy +y^2| =x^2 - 2xy +y^2. ##
Since, ##x^2 - 2xy +y^2 = (x-y)^2 \ge 0 \text{ for all x.} ##
