Is My Localized Yang-Mills Theory Solution Correct?
  • Context: Graduate
  • Thread starter Thread starter Antarres
    Theory Yang-mills
The discussion centers on the localization of internal symmetries in Yang-Mills theory, specifically examining the transformation properties of the quantity Kμ = ∂ℒ/∂∇μφ. The author introduces a multicomponent matter field φ^m(x) transforming under a Lie group G and localizes the symmetry by modifying the parameters θ^a to θ^a(x). The covariant derivative is defined as ∇μφ(x) = (∂μ + Aμ)φ(x), ensuring the invariance of the Lagrangian. The conclusion drawn is that the transformation δ₀(Kμ∇μφ) = 0 leads to the result δ₀Kμ = -Kμθ, which is confirmed as correct by another participant, Antarres.
  • Understanding of Yang-Mills theory and its mathematical framework.
  • Familiarity with Lie groups and their representations.
  • Knowledge of covariant derivatives in the context of gauge theories.
  • Experience with Lagrangian mechanics and field equations.
  • Study the implications of gauge invariance in Yang-Mills theories.
  • Explore the role of covariant derivatives in gauge field theories.
  • Investigate the properties of Lagrangians under local transformations.
  • Learn about the physical interpretations of Kμ and its significance in field theory.
The discussion is beneficial for theoretical physicists, particularly those specializing in gauge theories, quantum field theory, and anyone researching the mathematical foundations of Yang-Mills theory.
Antarres
While revising Yang-Mills theory, I have stumbled upon a certain problem, which I solved in a somewhat trivial way so I would like to check whether my reasoning is correct.
Let's say we have a multicomponent matter field ##\{\phi^m(x)\}## which transforms according to some Lie group ##G## of internal symmetry:
$$\phi'(x) = \phi(x) + \delta_0\phi(x)$$
$$\delta_0\phi(x) = \theta^aT_a\phi(x) \equiv \theta\phi(x)$$
where ##\theta^a## are parameters, ##T_a## are generators, and ##a## is multiplet index.
We localize this internal symmetries by ##\theta^a \rightarrow \theta^a(x)##. In order to maintain invariance of the Lagrangian, we introduce the covariant derivative:
$$\nabla_\mu \phi(x) = (\partial_\mu + A_\mu)\phi(x) \qquad A_\mu \equiv A^a_\mu T_a$$
where ##A_\mu## is the introduced gauge field.
Now when we localize the symmetry and introduce the covariant derivative in such a way that keeps Lagrangian invariant, we have that the covariant derivative of the field transforms according to the rule(by definition):
$$\delta_0\nabla_\mu\phi(x) = \theta\nabla_\mu\phi(x)$$
And we have that equations of motion can be written in covariant form:
$$\frac{\partial \mathcal{L}}{\partial \phi} - \nabla_\mu\frac{\partial\mathcal{L}}{\partial\nabla_\mu\phi} =0$$
We define the following quantity:
$$K^\mu = \frac{\partial\mathcal{L}}{\partial\nabla_\mu\phi}$$
and we're looking for the transformation properties of this quantity. I have solved it by saying that the quantity ##K^\mu\nabla_\mu\phi## must be gauge invariant, that is:
$$\delta_0(K^\mu\nabla_\mu\phi) = 0$$
from which it is easy to find that ##\delta_0K^\mu = -K^\mu\theta##. This is the correct solution, however I'm not sure whether my argument is correct. I have a gut feeling that it must be correct, but in that case I don't see why it would rigorously be true, although it seems trivially true for quadratic Lagrangian.
So it would be good if someone would look at this and point it out if I did this correctly. Thanks.
Antarres
It looks correct to me.
  • · Replies 30 ·
  • · Replies 17 ·
  • · Replies 0 ·
  • · Replies 26 ·
