THAN programming - puzzle - learning aid
The discussion revolves around programming in a simple, historical programming language designed for an imaginary machine, focusing on creating programs to manipulate paper tape based on specific instructions. Participants explore various programming tasks, share their solutions, and discuss the challenges involved in stopping input/output operations under certain conditions.
  • Homework-related
  • Some participants describe the programming language and its limitations, including the character set and instruction types.
  • One participant shares their solutions for the first two programming tasks and is working on the third, seeking to optimize their algorithm.
  • Another participant claims to have solved all three tasks and discusses their experience writing an interpreter for the language.
  • One participant challenges the correctness of a proposed solution, stating it does not stop all I/O as required.
  • A participant questions how to effectively stop all I/O, expressing concern that the only solution may lead to an infinite loop.
  • Another participant suggests that the correct solution involves using a specific instruction that does not involve I/O, highlighting its cleverness as part of the exercise.
  • One participant reflects on their personal experience with the problem from high school and mentions its historical context.
  • Another participant connects the problem to the concept of universal Turing machines, speculating on its development timeline.
Participants express differing views on the effectiveness of certain solutions, particularly regarding the stopping of I/O operations. There is no consensus on the best approach to achieve the desired outcome, and multiple competing views remain regarding the programming tasks.
Participants note the limitations of the programming language, including the restricted instruction set and the challenge of managing I/O operations effectively. The discussion reflects varying levels of experience with programming and problem-solving approaches.
Individuals interested in historical programming languages, programming puzzles, or educational approaches to teaching programming concepts may find this discussion relevant.
rcgldr
An extremely simple and old (1960's) programming language based on an imaginary machine. The machine has two peripherals, at paper tape reader, and a paper tape punch. The character set only includes two characters, Asterisk and Hypen. The CPU has 20 memory locations, which hold instructions, but only the first 10 locations, 0 through 9 are addressable via the branch instruction.
There are only 13 instructions, and 4 basic types of instruction:
T - Read a character from the tape reader. If the character read is a hyphen, execute next instruction. If the character read is an asterisk, skip the next instruction, and execute the instruction following the next instruction. If no character is read because the paper tape is past the end, then the machine will stop.
H - Punch a hypen, then execute next instruction.
A - Punch an asterisk, then execute next instruction.
0 - branch to location 0 and continue execution there.
1 - branch to location 1 and continue execution there.
2 - branch to location 2 and continue execution there.
9 - branch to location 9 and continue execution there.
Instruction execution can continue past memory location 9, but these memory locations can't be the target of a branch instruction.
Programming tasks:
1. Write a program to duplicate the paper tape in the reader using the paper tape punch.
2. Write a program to read the paper tape until 3 asterisks in a row are read, then start duplicating the paper tape as in program 1.
3. Write a program to read the paper tape until 3 asterisks in a row are read, then start duplicating the paper tape, but stop all I/O once 3 asterisks in a row are punched during the copy process.
Note that since there are only 13 instructions, trial and error will be good enough to write any of these programs.
To avoid spoilers, please white out your repsonse, or merely indicate that you've solved how to create programs 1, 2, and/or 3.
Sample program:
Code:
0 1 2 3 4 5 6 7 8 9 X X X X X X X X X X
T H A 0
This program will punch a hyphen and asterisk for every hyphen read, and puch an asterisk for every asterisk read. It's a broken copy program that you'll fix with program assignment 1.
Technology news on Phys.org
I've done 1 and 2... working on 3.
[spoilers]
1.
2 H T 1 A 2[/color]
2.
6 H T 1 A 2 T 6 T 6 T 6 2[/color]
[/spoilers]
As practice for 3, I'm trying to find the algorithm whose highest referenced memory location is lowest among algorithms that achieve the same thing.
Only one here taking the challenge so far? Note that this was a programming "puzzle" given to high school students just learning how to program.
Hah! Got 3 as well. That wasn't so hard after all.
[spoilers]
3.
T 0 T 0 T 0 8 H T 7 A T 7 A T 7 A[/color]
[/spoilers]
That was a nice problem. I also wrote an interpreter for the language this morning, so I could fool around with it a bit. 'Twas fun.
Not quite, your program continues on after the last instruction, and there are only 4 types of instructions, so it will not stop all I/O. You're close though.
How are you supposed to stop all I/O? If running out of commands on the command tape isn't enough, then the best I can do is have it end in an infinite loop. Seems like a poor solution, though.
[spoilers]
3.
T 0 T 0 T 0 9 7 H T 8 A T 8 A T 8 A 7[/color]
[/spoilers]
It may seem poor to you, but it's the correct solution, and part of the exercise, to realize that there is only one instruction that doesn't involve I/O and to use it for that purpose. It's a reasonably clever solution, demonstrating inovation, especially since it's targeted at students learning programming for the first time, although some experienced programmers have had difficulty with this problem.
I'm 55 years old now, and I received this problem in high school, back in 1968. I don't know when this problem was first developed.
  • · Replies 37 ·
  • · Replies 32 ·
  • Sticky
9K
