Vapor pressure of Thallium Iodide.
The vapor pressure of Thallium Iodide (TlI) is not well-documented in the lower temperature range, particularly from room temperature to 600K. The only available data starts at 713K, where the vapor pressure is recorded at 1 torr. Users are encouraged to extrapolate from this data and consult references 229, 465, and 474 for original research that may provide additional insights into TlI's vapor pressure characteristics.
  • Understanding of vapor pressure concepts
  • Familiarity with Thallium Iodide (TlI) properties
  • Basic knowledge of temperature scales (Kelvin)
  • Ability to interpret scientific data and references
  • Research the Antoine equation for vapor pressure calculations
  • Investigate the thermal properties of Thallium Iodide
  • Examine the original data in references 229, 465, and 474
  • Explore methods for extrapolating vapor pressure data
Chemists, materials scientists, and researchers interested in the thermodynamic properties of Thallium Iodide and its applications in high-temperature environments.
Capuchin
I've tried looking everywhere but cannot find much information on the vapor pressure of TlI.
I'm not very well versed in chemistry, so if I'm missing something obvious please let me know, I'm interested in how the vapor pressure changes from room temp up to something like 600K.
I've found only this data, which is at too high a temperature range:
http://webbook.nist.gov/cgi/cbook.cgi?ID=C7790309&Units=SI&Mask=4&Type=ANTOINE&Plot=on#Notes
Many thanks for any help,
Capuchin.
Chemistry news on Phys.org
http://pubs.acs.org/cgi-bin/archive.cgi/iechad/1947/39/i04/pdf/ie50448a023.pdf
Unfortunately, the data begins at 713K, where the vapor pressure is 1 torr (mm of Hg) but you might wish to extrapolate. Also, look up the references (229, 465, 474) for the original data. The should be more numbers there.
11K
10K
13K
12K
  • · Replies 21 ·
