Help with velocity/redshift/distance law
  • Context: Graduate
  • Thread starter Thread starter Dave Rutherfo
    Law
Dave Rutherford has derived a velocity/redshift/distance law expressed as v = c ln(1 + z) = H_0 d_0, where v is the recession velocity, c is the speed of light, z is the cosmological redshift, H_0 is the present Hubble constant, and d_0 is the present distance of the source. Feedback from Marcus indicates discrepancies between Rutherford's formula and values calculated using Morgan's calculator, particularly at higher redshifts. The discussion centers on whether Rutherford's law can accurately demonstrate that the universe's expansion rate is not accelerating, challenging the necessity of dark energy.
  • Understanding of cosmological redshift (z)
  • Familiarity with Hubble's Law (v = H_0 d)
  • Basic knowledge of the speed of light (c)
  • Experience with astronomical calculators, specifically Morgan's calculator
  • Investigate the mathematical derivation of Hubble's Law and its implications
  • Learn how to use Morgan's calculator for calculating recession velocities
  • Research the current observational limits of redshift and their impact on cosmological models
  • Explore alternative models of cosmic expansion that do not require dark energy
Astronomers, cosmologists, and physics students interested in the dynamics of cosmic expansion and the implications of redshift on the universe's acceleration.
Dave Rutherfo
I've derived a velocity/redshift/distance law,
[tex] <br /> v = c \ln(1 + z) = H_0 d_0<br /> [/tex]
where [itex]v[/itex] is the recession velocity, [itex]c[/itex] is the speed of light, [itex]z[/itex] is the cosmological redshift, [itex]H_0[/itex] is the present Hubble constant, and [itex]d_0[/itex] is the present distance of the source.
I would like to relate my law to the data, hopefully to show that the
expansion rate of the universe is not accelerating, thus eliminating the
need to invoke dark energy. Any help would be greatly appreciated.
For the derivation of this law and more, please click on the following link
http://www.softcom.net/users/der555/horizon.pdf
Thanks,
Dave Rutherford
Space news on Phys.org
Thanks,
Dave Rutherford
Your proposed equation looks wrong, Dave. Check it against the recession speeds given by Morgan's calculator. The link is in my sig. Be sure to enter the usual parameters 0.27, 0.73, and 71 for present matter fraction, lambda fraction, and Hubble rate.
When I do that and put in z=10, I get that the recession speed is 2.28 c.
You would have the recession speed be ln(11) c. That is 2.40 instead of 2.28. Well that is not too bad!
Now when I put in z=1090, I get that the recession speed is 3.3.
But you would have it be be ln(1091) = 7.0. That is way off. Either Morgan's calculator, or your formula, or both must be being pushed too far.
Maybe your formula is all right as a rough approximation as long as you just apply it to small redshifts, and will therefore suit your purposes (depending on how you intend to use it.) But as a rule I don't think it works. The relation between recession speed and redshift is not that simple.
Part of your equation is right though. Hubble law does say v = Hd. Hubble law does not talk directly about redshift. It gives the recession speed.
Thanks for the reply, Marcus.
Using the current limits of observation for redshift, 0 to 6, my values for recession velocity (my v), for a given redshift (z), are less than Morgan's calculator's corresponding values for recession velocity (Morgan's v) using the values 0.27, 0.73, and 71 for the other quantities that you gave above.
Here are the comparisons I came up with (all velocities x c):
z ... Morgan's v ... my v
0 ... 0.00 ... 0.00
1 ... 0.78 ... 0.69
2 ... 1.24 ... 1.10
3 ... 1.53 ... 1.39
4 ... 1.73 ... 1.61
5 ... 1.87 ... 1.79
6 ... 1.99 ... 1.95
If we only go by these results (which are based on the current limits of observation for redshift), my values seem to indicate that the universal expansion rate is either not accelerating or accelerating more slowly than the currently accepted rate. Correct? If yes, how can I determine which it is? If no, why not?
Thanks,
Dave
  • · Replies 18 ·
