Minimum distance in within a quadrilateral
  • Thread starter Thread starter bronxbombas
    Minimum
The problem involves finding the point P within a convex quadrilateral ABCD that minimizes the sum of distances to the vertices A, B, C, and D. The equation to minimize is Min(d(P,A)+d(P,B)+d(P,C)+d(P,D)), where distance is defined as d(X,Y)=sqrt((X-Y)·(X-Y)). The consensus among participants indicates that the optimal point P is likely the intersection of the diagonals AC and BD, as moving away from this point increases the total distance to the vertices.
  • Understanding of convex quadrilaterals and their properties
  • Familiarity with Euclidean geometry concepts
  • Basic knowledge of distance formulas in geometry
  • Ability to interpret mathematical optimization problems
  • Study the properties of convex quadrilaterals and their diagonals
  • Learn about optimization techniques in Euclidean geometry
  • Explore the concept of Fermat points in polygons
  • Investigate geometric proofs related to minimizing distances
Students in Euclidean geometry, mathematicians interested in optimization problems, and educators teaching geometric properties of quadrilaterals.
bronxbombas
Let A, B, C, D be the vertices of a convex quadrilateral. Convexity means that for each lines L(ab), L(bc), L(cd), L(da) the quadrilateral lies in one of its half-planes. Find the point P for which the minimum Min(d(P,A)+d(P,B)+d(P,C)+d(P,D)) is realized.
Min(d(P,A)+d(P,B)+d(P,C)+d(P,D)) is the equation we're trying to minimize.
distance=d(X,Y)=abs(X-Y)=sqrt((X-Y)x(X-Y)) where "x" is the dot product.
For starters, this is for my Euclidean geometry class, so there's no coordinates or Calculus, I presume. My initial guess is that the point that would minimize those distances would be the intersection of the diagonals but I can't figure out why.
I think you are probably right about the intersection of the diagonals. I'm not sure of a mathematical way to prove this, but I believe you can show that moving away from that point increase the sum of the lengths of those four lines. I can think of a few examples.
  • · Replies 18 ·
  • · Replies 19 ·
