Tension and Acceleration in a Pulley System
The discussion revolves around a physics problem involving two packing crates connected by a string over a frictionless pulley. The crates have different masses, and one is on an incline. The objective is to determine the acceleration of the crate on the incline and the tension in the string.
  • Participants discuss the forces acting on the crate on the incline and the implications of tension in the system. Questions are raised about the specific forces at play and how to set up the equations of motion.
The conversation is ongoing, with participants sharing insights about the forces involved and the nature of tension. Some guidance has been offered regarding the direction of tension and the role of weight, but no consensus has been reached on how to proceed with the calculations.
Participants note that the original poster is relatively new to the concept of tension in physics problems, which may influence their understanding and approach to the problem.
wowdusk
Two packing crates of masses m1 = 10.0 kg and m2 = 5.00 kg are connected by a light string that passes over a frictionless pulley . The 5.00 kg crate lies on a smooth incline of angle 40.0°. Find the acceleration of the 5.00 kg crate and the tension in the string.
i know there is only 1 tension because they area attached by a frictionless string, i just don't know where to go from there
What are the forces acting on the 5 kg block on the incline?
i told of everything the question gave me for info
Like, what forces act on the crate placed on the smooth incline?
Write the force equations and calculate.
thats where i am stuck...I'm kinda new to this tension stuff
Ok, you must have read that tension always acts away from the body. The weight of the body will also have an effect on its motion, in this case. Keeping these points in mind, work out the possibilities and inform us of the developments.
  • · Replies 18 ·
  • · Replies 18 ·
  • · Replies 27 ·
  • · Replies 33 ·
  • · Replies 38 ·
