Thermodynamic Properties of high pressure gases
The discussion revolves around finding thermodynamic properties of gases, specifically the kinematic and absolute viscosity of air at high pressure (330 bar) and a temperature of approximately 300 Kelvin. Participants share resources and methods for obtaining this data.
  • One participant inquires about sources for thermodynamic properties of gases at high pressure, specifically kinematic viscosity of air.
  • Another participant notes that different aerospace companies have their own versions of air tables, which can vary significantly.
  • A link to the NIST webbook is provided as a potential resource for the required data.
  • A repeated inquiry for the source of a viscosity value leads to a mention of the NIST REFPROP program, which is noted to cost $200.
  • A participant shares their findings using ASPEN software, providing specific values for dynamic and kinematic viscosity at the specified conditions.
Participants do not reach a consensus on a single source for the viscosity data, as multiple resources and methods are suggested, indicating a variety of approaches and potential discrepancies in values.
There are limitations regarding the assumptions made about the gas properties, as well as potential variations in data from different sources, which are not resolved in the discussion.
This discussion may be useful for researchers or engineers looking for methods to obtain thermodynamic properties of gases at high pressures, particularly in aerospace or related fields.
0507476h
Hi,
Anyone know where I can find thermodynamic properties of gases at high pressure? More specifically I need to find the kinematic viscosity or the absolute viscosity of air at around 300 degrees Kelvin and 330 bar.
Cheers
It depends on what gas and who you talk to. All the major aerospace companies for example have their own version of air tables (for high temp/high pressure). They can vary quite significantly.
http://webbook.nist.gov/chemistry/fluid/" should have the data you're after. Otherwise, a thermodynamic properties of air table at the local school library would have it too. You might even be able to find a table online if you search in google for "themodynamic properties of air."
0507476h said:
Hi,
Cheers
Air @ 300 K and 330 bar:
Kin. Viscosity = 0.00000090477 (ft²/s)
CS
CS
Thank-you for this, could you tell me how you calculated/where you found this data? Just so I can do it for myself in future as I reckon I will have a range of other pressures and temps to calculate kinematic viscosity for in future.
Thanks
Thanks
NIST has a program called REFPROP 8.0 that gives this information. Check the link above from Mech_Engineer and they will probably have a link for it. It cost $200 for copy last time I checked.
CS
Hi
I used ASPEN to find the answer
At 300K and 330 bar
Dynamic Viscosity=0.0299 cp =2.99e-5 Pa.sec
Kinematic Viscosity=8.566e-8 m^2/sec
  • · Replies 45 ·
