Work Done on Femur: Calculating Force Applied on 435mm Femur
  • Thread starter Thread starter as76
    Work Work done
The discussion focuses on calculating the work done by an external force of 151 N applied to a 435 mm femur, modeled as a hollow cylinder with an inner radius of 4.20 mm and an outer radius of 12.60 mm. Young's modulus for the bone is specified as Y = 1.67×1010 Pa. Key considerations include the type of force application (axial, torsion, shear) and the method for calculating work done on a deformable object.
  • Understanding of hollow cylinder mechanics
  • Familiarity with Young's modulus and material properties
  • Knowledge of work-energy principles in physics
  • Ability to calculate forces and deformations in materials
  • Research methods for calculating work done on deformable objects
  • Study the application of Young's modulus in biomechanical contexts
  • Learn about axial, torsion, and shear forces in structural analysis
  • Explore the mechanics of hollow cylinders in engineering applications
Students in physics or engineering, biomechanical researchers, and professionals involved in orthopedic mechanics will benefit from this discussion.
as76
How much work is done by an external force of 151 N when it is applied to a 435 mm femur? Model the bone as a hollow cylinder with inner radius R1 = 4.20 mm and outer radius R2 = 12.60 mm. Young's modulus for the bone is Y = 1.67×1010 Pa.
Could someone please help me approach this problem?
Thanks
Hi as76, welcome to PF.
(1) How is the force applied (e.g., axial, torsion, shear?)
(2) Do you know how to calculate work done by an applied force on a deformable object?
  • · Replies 23 ·
