How much energy does it take to heat a block of ice
The energy required to change a 35 g ice cube from ice at -15°C to steam at 117°C is calculated using specific heat values and phase change enthalpies. The specific heat of ice is 2090 J/kg·°C, water is 4186 J/kg·°C, and steam is 2010 J/kg·°C. The heat of fusion is 3.33 × 105 J/kg, while the heat of vaporization is 2.26 × 106 J/kg. The correct total energy required is 114734 J, factoring in the temperature changes and phase transitions accurately.
  • Understanding of specific heat capacity
  • Knowledge of phase changes (melting and vaporization)
  • Familiarity with the formula Q = m*c*ΔT
  • Basic proficiency in unit conversions (grams to kilograms)
  • Review the calculations for phase changes in thermodynamics
  • Learn about specific heat capacities of different substances
  • Explore the concept of enthalpy in chemical reactions
  • Practice problems involving heat transfer and temperature changes
Students studying thermodynamics, physics enthusiasts, and anyone needing to solve energy transfer problems involving phase changes and temperature variations.
Runaway
How much energy is required to change a 35 g ice cube from ice at −15 C to steam at 117 C?
The specific heat of ice is 2090 J/kg * C, the specific heat of water is 4186 J/kg * C, the specific heat of stream is 2010 J/kg * C, the heat of fusion is 3.33 × 10^5 J/kg, and the heat of vaporization is 2.26 × 10^6 J/kg.
Answer in units of J.
Q=m*L
Q=m*c*[tex]\Delta[/tex]T
35g*15C*2090J/kg*C - heat to raise ice's temp. to freezing
+ 3.33 * 10^5 J/kg *35g - heat to melt ice into water
+ 100C *4186J/kg*C *35g - heat to raise water temperature to boiling
+ 2.26*10^6 J/kg* 35g - heat to boil water into vapor
+ 2010 J/kg*C *117C *35g - heat to make vapor rise to 117 C
=114734 J
I tried this answer and the program says it's incorrect, what am I doing wrong?
The steam only has to rise 17C in temperature from 100C to 117C.
Thanks for your help... I completely missed that, I guess that's what I get for trying to do physics late at night. :)
  • · Replies 17 ·
10K
