Why is the sum of Lyapunov exponents negative in dissipative systems?
The discussion centers on the behavior of Lyapunov exponents in dynamical systems, particularly why the sum of these exponents is negative in dissipative systems. It is noted that while chaotic systems have a positive sum of Lyapunov exponents, the relationship between individual exponents and the overall trajectory exponent is complex. The confusion arises from the assumption that the sum of the exponents directly correlates with the exponent of the trajectory, which is not the case. Clarification suggests that the maximum Lyapunov exponent is crucial, rather than the sum, and that the sum's significance in dissipative systems remains unclear. Overall, the conversation emphasizes the need for a deeper understanding of the Lyapunov spectrum and its implications for system behavior.
waofy
Hi, the discussions in this forum have always been a great help to me as it seems there's always someone who's answered my question. However, this time I'm still puzzled.
People often talk about the sum of the Lyapunov exponents of a dynamical system (i.e. adding the exponents from each dimension in phase space) giving an indication of the overall behaviour of the system. For example, it is said that for a chaotic system the sum of the Lyapunov exponents is positive and for a dissipative system it is negative.
However, this doesn't make sense as the sum of the exponents is not the same as the exponent for the net trajectory through phase space.
e.g. in the case of a 3-dimensional phase space (x,y,z) with the system trajectory \begin{equation}
{\bf r}(t)=[x(t),y(t),z(t)]
\end{equation}
the separation between two trajectories is given by:
\begin{equation}
|\delta{\bf r}(t)|=e^{\lambda(t-t_{o})}|\delta{\bf r}(t_{o})|
\end{equation}
where lambda is the Lyapunov exponent of the trajectory. Now considering each dimension separately,
\begin{equation}
|\delta{\bf r}(t)|=|[\delta{x}(t),\delta{y}(t),\delta{z}(t)]|=|[e^{\lambda_{x}(t-t_{o})}\delta x(t_{o}),e^{\lambda_{y}(t-t_{o})}\delta y(t_{o}),e^{\lambda_{z}(t-t_{o})}\delta z(t_{o})]|=\sqrt{e^{2\lambda_{x}(t-t_{o})}\delta x(t_{o})^{2}+e^{2\lambda_{y}(t-t_{o})}\delta y(t_{o})^{2}+e^{2\lambda_{z}(t-t_{o})}\delta z(t_{o})^{2}}
\end{equation}(1)
where the lambdas are the exponent for each dimension. However, if the exponent of the trajectory was equal to the sum of exponents from each dimension,
\begin{equation}
|\delta{\bf r}(t)|=e^{(\lambda_{x}+\lambda_{y}+\lambda_{z})(t-t_{o})}|\delta{\bf r}(t_{o})|=e^{(\lambda_{x}+\lambda_{y}+\lambda_{z})(t-t_{o})}|[\delta x(t_{o}),\delta y(t_{o}),\delta z(t_{o})]|=e^{(\lambda_{x}+\lambda_{y}+\lambda_{z})(t-t_{o})}\sqrt{\delta x(t_{o})^{2}+\delta y(t_{o})^{2}+\delta z(t_{o})^{2}}
\end{equation}(2)
Clearly (1)=/=(2).
Am I missing something here? The only thing I can think of is that I haven't understood the meaning of the Lyapunov spectrum correctly. I've always assumed each exponent represents the the behaviour of trajectories moving in a single dimension but I could be wrong?
atyy said:
It's the maximum Lyapunov exponent that has to be positive, not the sum.
In addition, the system must have positive topological entropy. http://chaosbook.org/ (section 1.3.1).
The sum of the positive Lyapunov exponents is related to Kolomogorov-Sinai entropy by Pesin's formula http://www.scholarpedia.org/article/Pesin_entropy_formula.
Thanks, that makes more sense.
I think it is still true that in dissipative systems the sum of the Lyapunov exponents is negative though (http://books.google.co.uk/books?id=Uqc7zC7NULMC&pg=PA212&lpg=PA212#v=onepage&q&f=false" - first line). It makes sense that the overall exponent for the trajectory would be negative (which would also be true for a stable limit cycle) but I can't quite see why the sum should be. I'm just trying to work out what significance the sum has.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
