Horizontal projectile, NOT GIVEN INITIAL VELOCITY
The problem involves a cannon ball fired horizontally from a height of 400 m, landing 600 m away in the ocean. The participants are trying to determine the speed of the cannon ball upon impact with the water, given that the initial velocity is not provided.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss using kinematic equations to find time and velocity components. There are attempts to calculate the vertical and horizontal components of motion, with some questioning the assumptions made about initial velocities and the equations used.
The discussion is ongoing, with various participants providing insights and corrections regarding the calculations. Some guidance has been offered on how to approach the problem, particularly in distinguishing between vertical and horizontal motion. However, there is no clear consensus on the final velocity calculation yet.
Participants are working under time constraints, as one mentions having an exam soon. There is also confusion regarding the use of specific kinematic equations and the initial conditions of the problem.
xannaxiero
A cannon ball is fired horizontally off the top of a cliff that is
400 m high above the ocean. The ball hits the water 600 m
away. With what speed does the cannon ball enter the water?
I've tried using
d[itex]_{x}[/itex] = u[itex]_{x}[/itex]*t
d[itex]_{y}[/itex] = u[itex]_{y}[/itex]*t + 1/2a[itex]_{y}[/itex]*t[itex]^{2}[/itex]
and also solving for t
t = [itex]\sqrt{2y/g}[/itex]
So I found that t = 9 seconds
and that u[itex]_{x}[/itex] = 66.4
but i can't seem to figure out how to find final velocity, or speed.
I know what the correct answer is (111 m/s), I just can't figure out how it was gotten.
I have an exam in an hour, any help would be greatly appreciated!
You found the horizontal component of velocity, now find the vertical component. Once you have both components, you can figure out the total speed.
u[itex]_{y}[/itex] = 22.6
so if i do square root of 66.4^2 + 22.6^2 I should get my answer but i get 70.1 instead.
how do you find the final based on the x and y components?
How did you get that result?
t = 9 sec
so i did the following:
600 = uy + 1/2*9.8*9^2
solving for uy I got 22.6
xannaxiero said:
t = 9 sec
you want to use the displacement in the y-axis, not the x-axis
xannaxiero said:
t = 9 sec
For one thing, you are dealing with the vertical motion, not the horizontal. For another, you'll need a different kinematic equation--one relating velocity and time. (Using the equation you chose will trivially give you a zero initial velocity--which you already should know.)
ah yes. okay so that means 400 = uy*9 + 1/2 *9.8*9^2
so uy = .34
and i guess i did ux wrong, so ux is actually 600 = ux*9, giving ux = 67
but from here i still don't know how to find the final velocity
so uy = .34
No. Done more accurately, you'll get uy = 0. (9 seconds is just an approximate answer.) Realize that that equation gives the initial velocity, which is not what you want. You should know that the initial vertical velocity is zero. (You used that fact to find the time.)
No, you were right the first time. (How did you find the time?)
How does velocity change for accelerated motion? What's the definition of acceleration?
velocity increases due to acceleration... a = change in velocity/change in time
so we have a change from zero to 66.4 over the course of 9 seconds
meaning acceleration is 7.4 m/s ?
and i know v = vi + at
so i feel like i could do v= 0 + 7.4*9
giving me 66.4, which is wrong.
Good. Now apply that to the vertical motion.
No, the horizontal motion is not accelerated.
That's the equation you need. Apply it to the vertical motion.
What is the acceleration of a falling body?
  • · Replies 21 ·
