Understanding the Basic Operator Equation for Quantum Mechanics
  • Thread starter Thread starter genericusrnme
    Operator
The discussion revolves around a quantum mechanics operator equation involving the Hamiltonian and a density operator expressed as a sum of projectors. Participants are trying to clarify the relationship between the left and right actions of the Hamiltonian on the density operator.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to understand the operator equation and expresses confusion about the next steps. Some participants question the correctness of the original equation and explore the implications of taking expectation values. Others suggest examining the definitions of the operators involved and their actions on states.
Participants are actively engaging with the problem, with some providing insights into the equivalence of operators and discussing the implications of the Schrödinger equation. There is a recognition of differing interpretations regarding the behavior of the density operator.
There is mention of a reference to Sakurai's book, indicating that the original poster's equation is derived from established literature. The discussion also highlights the distinction between time-dependent and time-independent states in the context of the problem.
genericusrnme
Can someone explain to me how
[itex]H(\sum_n w_n |a_n><a_n|) = \sum_n w_n(H|a_n><a_n|-|a_n><a_n|H)[/itex]
I've done this before and I remember being confused about it before then finding out it was something simple.. I should really start filing my notes away for such an eventuality :frown:
I can't seem to work out what the next step is at all.
What you wrote is not correct. If you take an expectation value of your expression in the mth state, you'd find 0 on the RHS. We can find a correct statement if we consider the operators
[tex]O_L = \sum_n w_n (H| a_n \rangle )\langle a_n| ,[/tex]
[tex]O_R = \sum_n w_n | a_n \rangle (\langle a_n|H) .[/tex]
The expectation values in an arbitrary state are equal:
[tex]\langle a_m | O_L | a_m \rangle = \sum_n w_n \langle a_m |H| a_n \rangle \langle a_n| a_m \rangle = w_m \langle a_m |H| a_m \rangle,[/tex]
[tex]\langle a_m | O_R | a_m \rangle = \sum_n w_n \langle a_m | a_n \rangle \langle a_n|H| a_m \rangle = w_m \langle a_m|H| a_m \rangle ,[/tex]
where in both cases we used [itex]\langle a_n| a_m \rangle = \delta_{nm}.[/itex]
So in this sense, [itex]O_R=O_L[/itex]: we can let the operator act from the right or left side. This is the same way that expectation values work
[tex]\langle a_n | H | a_m \rangle = \langle a_n | (H | a_m \rangle ) = (\langle a_n | H) | a_m \rangle.[/tex]
We can therefore write
[tex]H \left( \sum_n w_n | a_n \rangle \langle a_n| \right) = \frac{1}{2} \sum_n w_n \Bigl[ ( H | a_n \rangle ) \langle a_n| + | a_n \rangle (\langle a_n|H) \Bigr].[/tex]
Yeah, I kept coming to that conclusion too yet what I wrote is what is in Sakurai's book..
[itex]i\ \hbar \partial_t \rho = H \rho \neq -[\rho , H][/itex]
Where [itex]\rho = \sum_n w_n |a_n \rangle \langle a_n |[/itex]
I'll attatch an extract
OK, the point there is that [itex]\rho[/itex] does not satisfy Schrödinger's equation so [itex]i\ \hbar \partial_t \rho \neq H \rho[/itex]. Instead you have to use
[tex]i \hbar \frac{\partial}{\partial t} |\alpha^{(i)},t_0;t \rangle \langle \alpha^{(i)},t_0;t | = \left( i \hbar \frac{\partial}{\partial t} |\alpha^{(i)},t_0;t \rangle \right) \langle \alpha^{(i)},t_0;t | + |\alpha^{(i)},t_0;t \rangle \left( i \hbar \frac{\partial}{\partial t} \langle \alpha^{(i)},t_0;t | \right)[/tex]
and
[tex]i \hbar \frac{\partial}{\partial t} \langle \alpha^{(i)},t_0;t | = - \left( i \hbar \frac{\partial}{\partial t} |\alpha^{(i)},t_0;t \rangle \right)^\dagger .[/tex]
The derivation I gave above is valid for time-independent states and wouldn't work here.
Ah!
I remembered it being something simple :L
Thanks buddy :biggrin:
  • · Replies 77 ·
9K
  • · Replies 16 ·
