Does conservation of energy for unsteady ideal fluid hold?
The discussion revolves around the conservation of energy in the context of unsteady ideal fluids, particularly examining whether the energy density expression holds in such scenarios. Participants explore theoretical implications, mathematical formulations, and conceptual clarifications related to energy density in fluid dynamics.
  • One participant asserts that for an ideal, steady fluid in a gravitational field, the energy density is constant, questioning if this holds for unsteady fluids and what causes changes in mechanical energy.
  • Another participant warns that pressure should not be included in the energy density equation, arguing that it does not contribute to energy density in incompressible fluids.
  • A different viewpoint suggests that pressure can be regarded as a form of potential energy for fluid elements, despite not being true energy.
  • Another participant challenges the idea of ascribing pressure as energy, arguing that it leads to double counting when calculating total energy.
  • One participant proposes that recognizing both gravitational and pressure potential energy is valid, especially in unsteady flows where gravitational potential energy may change.
  • A later reply clarifies that energy is defined in terms of work and provides an example of calculating energy in a tank, concluding that pressure energy does not factor into the energy of incompressible liquids.
  • One participant concludes that in nonstationary flows, the energy expression is not constant, while also referencing a potential flow condition that modifies the energy equation.
Participants express differing views on the role of pressure in energy density and whether it should be considered as potential energy. There is no consensus on whether the energy density expression remains constant in unsteady ideal flow, indicating ongoing debate.
Discussions involve assumptions about fluid properties (incompressibility, inviscidity) and the definitions of energy density and potential energy. The implications of unsteady flow on energy conservation remain unresolved.
This discussion may be of interest to students and professionals in fluid dynamics, physics, and engineering, particularly those exploring energy conservation principles in fluid systems.
dEdt
My text was able to show that for an ideal (incompressible and inviscid) and steady fluid in a gravitational field, the energy density [itex]E=\frac{1}{2}\rho u^2 + \rho\chi+P[/itex] is constant for any fluid element, where [itex]\chi[/itex] is the gravitational potential. That is
[tex]\frac{DE}{Dt}=\frac{\partial E}{\partial t} + \mathbf{u}\cdot\nabla E=0[/tex].Does this hold for an unsteady ideal fluid? If not, what causes the change in the mechanical energy of the fluid element?
Hello dEdt,
beware, energy density is [itex]\epsilon = \frac{1}{2}\rho u^2 + \rho\chi[/itex]. Pressure does not contribute to energy density. For example, consider incompressible liquid; there can great pressure in it but no work is required to produce it, since it does not change its volume. The equation you wrote is supposed to mean that the right-hand side is constant along the streamline, even if the fluid is moving. This is true for incompressible liquid without friction. For compressible liquid there is enthalpy density there instead of pressure.
Jano
Sure, but the force on a fluid element of volume [itex]\delta V[/itex] due to pressure is [itex]-\nabla P \delta V[itex]. So for that fluid element, it's possible to regard P as a potential energy (per unit volume). It might not be true energy, but I still think it's valid to regard it as a form of potential energy, at least for the purposes of calculations, no?[/itex][/itex]
It is not correct to regard pressure of liquid as density of energy. You would get wrong total energy of the liquid.
Consider water in a tank.
The buoyant force on a small volume of fluid is indeed [itex]\mathbf F = -\frac{\nabla p}{\rho} \Delta m[/itex], so you can view [itex]p/\rho[/itex] as a potential of the buoyant force. But you should not ascribe this potential energy to the fluid element, because then if you sum up these energies, you will get [itex]\int_V pdV = \int \rho g h dV[/itex], which however is already accounted for by the potential energy in gravitational field. So counting pressure as energy actually accounts for this energy twice, which is wrong.
I don't see the problem with recognizing two sources of potential energy, one from gravity and the other from pressure. In your example, [itex]K+\int{\rho ghdV} + \int{\rho ghdV}[/itex] is conserved if [itex]K+\int{\rho ghdV}[/itex] is conserved, because h doesn't change. In other situations, such as in unsteady flow, where the total gravitational potential energy changes, it is only the first expression that is conserved, because although the walls of the container (ie the source of the pressure) don't do any work, pressure does do work when the fluid expands, which is the only time gravitational potential energy will ever change.
At any rate, you can frame my original question this way: in steady, ideal flow, there's a mysterious quantity [itex]E=\frac{1}{2}\rho u^2+\rho\chi+P[/itex] which is conserved for any fluid element. Is this quantity still conserved in unsteady ideal flow?
Think of it this way. Energy is defined in terms of work. How much work do you need to fill a tank of height [itex]h[/itex] and base area [itex]S[/itex] with water (density [itex]\rho[/itex]), if the water is initially in the lake at the same level as the base of the tank?
This work defines energy of the system. You can calculate this by adding the small amount of work needed to raise the level of the water by [itex]\Delta h[/itex]. You will see the work is [itex]\frac{1}{2} S\rho gh[/itex] which defines the total energy of the system. There is no trace of pressure energy, precisely because the liquid is incompressible and it does not take any work to increase the pressure in the liquid.
To your question: in nonstationary flows the expression is not constant.
If the nonstationary flow is potential (means [itex]\mathbf v = \nabla\phi[/itex]), the equation reads
[tex] \frac{\partial \phi}{\partial t} + \frac{1}{2}v^2 +\chi + p/\rho = f(t)[/tex]
for some function [itex]f(t)[/itex].
Okay, I've understood. Thanks for taking the time to explain.
Glad to be of help,
Jano
  • · Replies 18 ·
  • · Replies 48 ·
  • · Replies 32 ·
