Modeling bolt holes as stress concentrators in I beam bending
This discussion focuses on modeling bolt holes as stress concentrators in I beam bending. The bending moment of inertia is calculated using the formula I = Σ(I + Ad²), where I = (1/12)bh, with b as the base and h as the height. Stress is determined using σ = Md/I, and the average stress around a bolt hole is calculated with σaverage = P/((w-2r)t), where w is the width of the flange, r is the radius of the hole, and t is the thickness of the flange. The introduction of bolt holes significantly affects the beam's factor of safety, and while proper bolt preloading may mitigate some issues, the geometry and location of the holes are critical factors in stress analysis.
  • Understanding of bending moment of inertia calculations
  • Familiarity with stress concentration factors and their implications
  • Knowledge of finite element analysis (FEA) principles
  • Basic concepts of load distribution in structural engineering
  • Research Peterson's Stress Concentration Factors and their applications
  • Learn about finite element analysis (FEA) software for structural modeling
  • Study the effects of bolt preloading on structural integrity
  • Explore advanced bending moment calculations for asymmetric beams
Structural engineers, mechanical engineers, and anyone involved in the design and analysis of beam structures, particularly those incorporating bolt holes and stress concentration factors.
foundry
curious as to the proper way to model this.
beam is symmetric so centroid is in the middle (used to calculate distance from centroid d in bending moment of inertia equation)
I =[itex]\sum[/itex](I + Ad2)
I=[itex]\frac{1}{12}[/itex]bh
b=base
h=height
d=distance of the area's center to total centroid
A=area of section
using max moment from a FBD the stress is calculated
σ = [itex]\frac{Md}{I}[/itex]
say a bolt hole is placed on the top flange, to me it makes sense to model it this way...
take just the top flange use stress calculated from above equation to find the compressive load P via this equation and the cross sectional area of the flange A
σ = [itex]\frac{P}{A}[/itex]
now modeling the hole as a stress concentrator
σaverage = [itex]\frac{P}{(w-2r)t}[/itex]
w = width of flange
r = radius of hole
t = thickness of flange
calculate [itex]\frac{r}{w}[/itex] in order to find a value for K (tabled value)
σmax = K σaverage
like I said this makes sense to be but when I run through a sample calculation a beam originally having a factor of safety of 2 ends up not being able to withstand the load just by introducing a bolt hole. thanks for your time.
I take it with the proper bolt preloading, these holes aren't an issue? Is that a correct assumption?
Their effect on the beam will depend largely on the geometry and their location on the flange. It could be as long as the holes are far from an edge that you can just consider them to be located in a plate in tension, in which case there are well-documented stress concentration factors to calculate their stress rise. It will also depend on your loading conditions, but I wouldn't assume proper preload on a bolt in the hole will solve your problem.
Otherwise your best bet is FEA, but it brings its own set of limitations and challeges. Interestingly, many stress concentration factors (e.g. Peterson's Stress Concentration Factors) are calculated using parametric FEA models and curve fits to their outputs.
  • · Replies 30 ·
10K
