Scalefactor calculations for special cases using the Friedmann Equation
The discussion revolves around calculating the scale factor a(t) and redshift z at the point of matter-radiation equality using the Friedmann Equation. Participants explore the relationships between energy densities of matter and radiation, and how these relate to the scale factor in different cosmological models, including matter-only and radiation-only universes.
  • Homework-related
  • One participant requests assistance with deriving the scale factor and redshift at matter-radiation equality, as well as estimating the time of equality using different cosmological models.
  • Another participant suggests starting with the dependence of dust and radiation energy densities on the scale factor, referencing the conservation of energy-momentum and properties of the radiation energy-momentum tensor.
  • Several participants express confusion about the initial steps for deriving the scale factor in a radiation-dominated universe, indicating a need for clarification on the appropriate formulas.
  • One participant mentions the importance of scaling laws to find the scale factor at matter-radiation equality based on current densities.
  • Another participant emphasizes the relationship between average energy per photon and the scale factor, suggesting assumptions about curvature and density for calculations.
  • A participant shares a calculated value for the scale factor for part i and seeks confirmation on its correctness, while also expressing uncertainty about the method for part ii.
  • Additional insights are provided regarding the relationships between scale factors and time in radiation and matter-dominated scenarios, noting the proportionalities involved.
Participants generally agree on the need to derive the scale factor and understand the relationships between energy densities, but there is no consensus on the specific methods or formulas to use, as multiple viewpoints and uncertainties are present.
Participants have not fully resolved the assumptions needed for calculations, such as the treatment of curvature and the specific values for densities. There are also unresolved mathematical steps in deriving the scale factor and time of equality.
karan9
(i) Obtain the scale factor a(t) and redshift z when the energy density of matter and radiation were equal.
(ii) Next use the a(t) relation for a matter-only universe to estimate the time of matter-radiation equality.
(iii) Repeat (ii) but using the a(t) relation for a radiation-only universe. Which approximation, (ii) or (iii), is closer to the correct answer?
Can someone help me?
Thanks!
Space news on Phys.org
How far have you gotten? You should start by figuring out how dust and radiation energy densities depend on the scale factor. You can find this out using the conservation of energy-momentum, and the fact that radiation energy-momentum tensor is traceless.
After that you just equate the expressions you got, and integrate Friedmann equations
Ive understood the concept of how I'm supposed to do it. But, I am confused on how to start the radiation equation. As in what formula do I use to find the scale factor for a radiation dominated universe?
The way I understand the question is that you should use the scaling laws to find the value of scale factor at matter-radiation equality as a function of their densities today.
Just remember that the average energy/photon is proportional to 1/a. I'm guessing that you should assume zero curvature, that the density is always at critical, and that the kinetic energy of the matter can be neglected. You'll need to assume some value for the amount of matter per photon (about 10-35kg/photon).
Oh that clears up part i for me. Thanks guys! My answer for part i comes to a=2.8*10^-4
Is that right?
I am confused about the method we have been asked to use for part ii.
Do i just plug in the value of a into the (da)^2 = Ho^2/a^2 equation and solve for 't' ?
Am I missing something?
Thanks Again.
Also remember that the average energy per blackbody photon is ~2.7kT, which is a little higher than you might guess.
Just to give a few clues, with radiation only, you'll find that a [itex]\propto[/itex] t1/2 whereas with matter only, a [itex]\propto[/itex] t2/3. Then [itex]\rho[/itex] [itex]\propto[/itex] k/tn where n is a certain positive integer that I won't disclose (same integer for radiation and matter), and k is a constant, although kradiation is slightly larger than kmatter.
  • · Replies 18 ·
