How bulbs and globes are vacuumed and sealed?
  • Thread starter Thread starter CognitiveNet
The discussion centers on the process of sealing glass bulbs, such as plasma globes and light bulbs, after air has been removed using a vacuum pump. It explores the methods and sequence of actions involved in creating a vacuum and sealing the glass.
  • One participant describes a method where a long neck is created for the vacuum pump, and the glass is heated to seal the neck after air is pumped out.
  • Another participant questions the timing of the sealing process, asking whether it occurs before or after the air is removed.
  • A different participant asserts that sealing must occur after the air is pumped out to maintain the vacuum, emphasizing the impracticality of sealing beforehand.
  • Some participants express confusion about the question of when the sealing occurs, indicating that it is a common point of misunderstanding.
Participants generally disagree on the timing of the sealing process, with some asserting it must happen after the vacuum is created, while others question this sequence. The discussion remains unresolved regarding the exact process.
There are assumptions about the understanding of vacuum sealing processes and the physical properties of glass when heated, which are not explicitly detailed in the discussion.
CognitiveNet
How can a plasma globe or a light bulb made of glass be sealed after the air has been removed by a vacuum pump?
You first make it with a long neck where the vacuum pump is attached. Then you heat the glass of the neck until it becomes soft, closes the neck and seals the bulb.
Is it sealed before or after the air is pumped out?
Think it through! (Hint, the process of sealing makes it impossible for air to get in or out...)
What a strange question! If you seal it before you pump the air out, you no longer have a way to pump the air out!
The point is this- you mask a long thin glass neck, pump the air out, then, while the neck is still attached to the vacuum pump, with the vacuum still good, you heat the neck until it is soft, and use some tool to squeeze it closed.
I am glad I was not the only one who thought that question was odd.
  • · Replies 21 ·
  • · Replies 21 ·
  • · Replies 29 ·
