Oxidation states of transition metals when reactions occur
The discussion revolves around the oxidation states of transition metals, particularly iron and copper, during reactions with acids. Participants explore the complexities of determining which oxidation state to use in various scenarios, emphasizing the role of empirical data and standard potentials.
  • One participant notes that while sodium has a clear oxidation state of +1, the oxidation state for iron in reactions with acids is less straightforward, suggesting +2 as a starting point.
  • Another participant argues that using a standard potentials table is necessary, but acknowledges that this may not always yield correct results in specific cases.
  • It is mentioned that iron typically gets oxidized to Fe(II) when H+ is the only oxidizing agent, due to the high E0 for the Fe(II)/Fe(III) oxidation.
  • A participant points out that copper does not dissolve in non-oxidizing acids, implying that the question of its oxidation state in such contexts may be irrelevant.
  • There is a discussion about the lack of universal rules governing oxidation states, with one participant suggesting that rules are derived from empirical data rather than being inherently defined.
  • Another participant emphasizes that oxidation states are not fundamental properties but rather tools for balancing equations, highlighting their limitations.
Participants express uncertainty regarding the determination of oxidation states for transition metals, indicating that multiple competing views remain on how to approach these reactions. There is no consensus on a definitive method or rule to follow.
Participants acknowledge the limitations of oxidation states as a concept and the dependence on empirical data, suggesting that the discussion is influenced by specific conditions and definitions that may not be universally applicable.
sgstudent
When metals such as sodium react with an acid, a salt and hydrogen gas is produced. and we know for sure the oxidation state of sodium in the compound will be +1. But for other metals such as iron, when they rest with acids which oxidation state do I use? I'm unsure if I'm supposed to use the lowest oxidation first as when iron reacts with an acid its oxidation state is +2 first. But for other metals which one do I use first such as copper?
Thanks for. The help guys! :smile:
Chemistry news on Phys.org
There is no simple answer to that other than "use standard potentials table" (but I think even then you can be wrong in some specific cases).
If there is nothing else present (that is, the only oxidizing agent is H+) iron gets oxidized to Fe(II), as E0 for Fe(II)/Fe(III) oxidation is way too high.
From the same table you can read copper doesn't dissolve in non-oxidizing acids, so the question about products is a moot.
So for most of the stuff there's no real rule to follow rather its based on empirical data? Thanks for the help Borek!
Rules are made up from the empirical data, after all it is reality that defines what happens, not rules that we invent.
Oxidation state is not a fundamental property of atoms but in fact little more than a mnemotechnics to balance equations. It is quite astonishing that it can be used to systematize to some extent chemical compounds but one should be aware of its limitations.
