Molecular mass of a substance at NTP?
  • Thread starter Thread starter xiphoid
    Mass Molecular
The molecular mass of a substance that occupies a volume of 5.6L at Normal Temperature and Pressure (NTP) can be calculated using the ideal gas law. NTP is defined as air at 20°C (293.15 K) and 1 atm (101.325 kPa). The discussion clarifies that NTP is distinct from STP (Standard Temperature and Pressure), which is defined by IUPAC as air at 0°C and 1 atm. Understanding these definitions is crucial for accurate calculations in chemical processes.
  • Understanding of the ideal gas law
  • Familiarity with molecular mass calculations
  • Knowledge of NTP and STP definitions
  • Basic concepts of pressure and temperature in chemistry
  • Research the ideal gas law and its applications in chemistry
  • Learn about the differences between STP, NTP, and SATP
  • Explore molecular mass calculation techniques for gases
  • Investigate the significance of standard conditions in chemical reactions
Chemistry students, chemical engineers, and professionals involved in gas measurements and calculations will benefit from this discussion.
xiphoid
M g of a substance when vapourised occupy a volume of 5.6L at NTP, molecular mass of the substance will be?
Here, what does the NTP refer to [normal temperature pressure?]
options are
M, 3M, 2M, 4M
Chemistry news on Phys.org
i guess so
from http://www.engineeringtoolbox.com/stp-standard-ntp-normal-air-d_772.html
STP - Standard Temperature and Pressure
STP is commonly used to define standard conditions for temperature and pressure which is important for the measurements and documentation of chemical and physical processes:
  • STP - Standard Temperature and Pressure - is defined by IUPAC (International Union of Pure and Applied Chemistry) as air at 0°C (273.15 K, 32°F) and 105 pascals
  • STP - commonly used in the Imperial and USA system of units - as air at 60°F (520 °R) and 14.696 psia (15.6°C, 1 atm)
Note that the earlier IUAPC definition of STP to 273.15 K and 1 atm (1.01325 105 Pa) is discontinued.
1 Pa = 10-6 N/mm2 = 10-5 bar = 0.1020 kp/m2 = 1.02x10-4 m H2O = 9.869x10-6 atm = 1.45x10-4 psi (lbf/in2)
NTP - Normal Temperature and Pressure
NTP is commonly used as a standard condition for testing and documentation of fan capacities:
  • NTP - Normal Temperature and Pressure - is defined as air at 20°C (293.15 K, 68°F) and 1 atm (101.325 kN/m2, 101.325 kPa, 14.7 psia, 0 psig, 29.92 in Hg, 760 torr). Density 1.204 kg/m3 (0.075 pounds per cubic foot)
SATP - Standard Ambient Temperature and Pressure
SATP - Standard Ambient Temperature and Pressure is also used in chemistry as a reference:
  • SATP - Standard Ambient Temperature and Pressure is a reference with temperature of 25°C (298.15 K) and pressure of 101 kPa.
  • · Replies 18 ·
