Linearly independent sets within repeated powers of a linear operator
The discussion revolves around a linear transformation T applied to a vector space W, specifically focusing on the linear independence of a set generated by repeated applications of T to certain vectors. The original poster is tasked with proving that a specific set of vectors remains linearly independent under the given conditions of T.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to use induction to establish linear independence but expresses uncertainty about the approach and its rigor. They also question the need for additional base cases in their reasoning.
  • Some participants suggest considering the implications of linear dependence and the minimal index of vectors involved, prompting further exploration of the relationships between the vectors.
  • Others inquire about the validity of rearranging terms in linear combinations to demonstrate independence, raising questions about the nature of linear combinations and independence.
The discussion is ongoing, with participants providing guidance and prompting further exploration of the original poster's ideas. There is a collaborative effort to clarify concepts and refine the reasoning process, although no consensus has been reached yet.
The original poster mentions their background and upcoming placement exam, indicating a context of preparation and learning in linear algebra and vector calculus.
Fractal20
Suppose that T:W -> W is a linear transformation such that Tm+1 = 0 but Tm ≠ 0. Suppose that {w1, ... , wp} is basis for Tm(W) and Tm(uk) = wk, for 1 ≤ k ≤ p. Prove that {Ti(uk) : 0 ≤ i ≤ m, 1 ≤ j ≤ p} is a linearly independent set.
By definition of a basis w1, ..., wp are linearly independent. Now suppose Tm - 1(uk) is not linearly independent from the w's. Then it can be written as some sum of linear combinations of the w's which is equivalent to saying Tm-1(uk) = c1Tmu1 + ... + cpTmup. If both sides are left multiplied by T then we have Tm = the linear combination of Tm + 1 of the ui's which by definition are all 0. But then we have Tm(uk) = 0 = wk by definition but this is a contradiction since wk cannot be 0 if it is linearly independent of the other wi's.
From here, it seems like this same process can be applied backwards but I am not sure how it can be rigorously done in an elegant manner. I think I can use induction and say given that Tq(uk) is linearly independent from {Tr(uk): q + 1 ≤ r ≤ m, 1 ≤ k ≤ p} then Tq - 1(uk) is linearly independent for all k for if it wasn't then ... the same argument as the base case but applying repeated left multiples of T to keep creating 0 terms on the right eventually yielding the same contradiction of having wk = 0. This seems bulky and I am not confident it works. Also, I'm not use to using induction in a downwards trend and don't know if I would need to do an additional bottom base case for T1 specifically.
Is this weird attempt at induction valid? Do you have any more elegant approaches? Thanks!
For background, I am starting grad school in the fall and have to take a placement exam in linear algebra and vector calculus. This is a question off of one of the earlier placement exams.
Your idea is right. But it is really... well.. backwards :)
Say some Tiuk are linearly dependent. At least one of them has the minimal i. Does it give you any ideas?
Thanks! I think that helps nicely. I was a little unsure that I would need to account for the linear combination involving Tq terms for q < i. But I think I see now that if Tqui is linearly independent then if it's coefficient wasn't 0 then we could rearrange it to show that it was indeed linearly dependent. Is that true? If you have a set of vectors and know that some are linearly independent of all the rest, then the linear dependence of any of the vectors can't involve a linearly independent vector? Thanks so much, I am sure I will keep posting questions the next few weeks.
You have a linear combination, where some vectors will have a minimum i. Put them on the left side of the equation. The ones on the right will all correspond to higher degrees of the operator. Now apply the operator (m - i) times to the whole thing (that's your idea). What do you get?
The only case when that can't work is when all i = m. But what do we have in that case?
  • · Replies 21 ·
  • · Replies 28 ·
