Electric Field Distribution of a disk
The discussion focuses on calculating the electric field (E) at a point P located 10 cm above the center of a thin disc with a central hole. The disc has a radius of 60 cm and a hole of radius 30 cm, with a total charge of 10^-3 C uniformly distributed over its surface. Participants discuss the setup of the differential charge element (dq) using the formula dq = σ2πrdr, where σ represents the surface charge density derived from the total surface area of the disc.
  • Understanding of electric field concepts and calculations
  • Familiarity with surface charge density (σ) and its calculation
  • Knowledge of integration techniques for continuous charge distributions
  • Basic physics of electron motion in electric fields
  • Calculate the total surface area of the disc to determine the surface charge density (σ)
  • Learn about the integration of electric fields from continuous charge distributions
  • Explore the concept of electric field lines and their symmetry in charge distributions
  • Investigate the motion of charged particles in electric fields, specifically for electrons
Physics students, electrical engineers, and anyone interested in electrostatics and electric field calculations.
davidflip
Hi can someone help me with this problem?
A thin disc of radius 60 cm has a hole its center of radius 30 cm. A total charge of
10^-3C is distributed uniformly on its surface. Find E at a point P which is 10 cm. on the central axis of this disc.
What would be the acceleration of an electron passing through point P ?. Mass of electron = 9.11*10^-31 Kg.
How would I set up dq for this?
would it simply be dq= σ2∏rdr? and if it is what is the numerical value for σ?
Thank you!
You have a uniform charge distribution. Can you calculate the total surface area of your disk? This should give you σ.
If you use the symmetry of the setup, you can use that.
