Solving Unstable ODE: Theory, Stability & Continuity
  • Context: Graduate
  • Thread starter Thread starter muzialis
    Ode
The discussion focuses on solving the ordinary differential equation (ODE) $$ \dot{y} = min \, (y, A) + B\, sin(t)$$, where A and B are constants. The user expresses concern about the accuracy of their numerical solution, which exhibits significant oscillations. They seek guidance on theories related to ODE well-posedness, continuity with respect to initial data, and stability. A participant suggests that the ODE can be solved analytically for specific cases, providing a piece-wise solution approach to validate the numerical results.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with numerical solution techniques for ODEs
  • Knowledge of stability analysis in differential equations
  • Basic concepts of piece-wise functions and continuity
  • Study the theory of well-posedness for ODEs
  • Learn about stability analysis techniques for differential equations
  • Explore analytical methods for solving ODEs, particularly piece-wise solutions
  • Investigate numerical methods for improving ODE solution accuracy, such as Runge-Kutta methods
Mathematicians, engineers, and researchers involved in numerical analysis, particularly those working with ordinary differential equations and seeking to improve solution accuracy and stability.
muzialis
Hello there,
I am solving numerically the ODE
$$ \dot{y} = min \, (y, A) + B\, sin(t)$$ , A,B being constant.
I obtain a very "wiggled" solution which is very fine to me actually, as it echoes the problem I am studying.
However, as the numerical solution scheme is quite "rudimentary" I am wondering if I am getting an accurate answer.
In this respect I am wondering if somebody could point me towards a suitable theory for ODE to study their well-posedness, continuity with respect to inital data, stability.
I am no expert, but I understand the problems one would encounter if trying to solve the heat equation with negative conductvity!
The ODE, in the regime $$ y(t) < A$$ is of they type $$ \dot{y} = y + f(t)$$ which is prone to diverging exponentially.
I am trying to understand if the solution I find is meanigful or just "computer noise".
Thanks
muzialis said:
Hello there,
Thanks
The ODE looks simple enough that you could solve it analytically for an example case or two. For example, suppose ##y(0) = y_0 < A##. Then initially your ODE is just ##\dot{y} = y(t) + B\sin(t)##, as you said, which has solution ##y(t) = (y_0+B/2)e^t - (B/2)(\sin t + \cos t)## (double-check that). This solution is valid until it grows to ##y(t_1) = A##. At this point it must satisfy the ODE ##\dot{y} = A + B\sin t##, which has solution ##y(t) = y(t_1) + A(t-t_1) - B(\cos t - \cos t_1)##. You can find ##t_1## by setting ##y(t_1) = A## in your first solution for ##t<t_1##, and ##y(t_1)## is just A. (You will probably have to solve numerically for ##t_1##). If your parameter values are such that y(t) dips below A again, you would need to find the time ##t_2## at which that happens and solve the ODE with ##\mbox{min}(y,A) = y## again, and so on.
In this way you can construct a piece-wise analytic solution for some simple parameter choices which you can test against your numerical solution.
  • · Replies 28 ·
  • · Replies 0 ·
  • · Replies 16 ·
  • · Replies 24 ·
