Designing a Simple SMPS Power Supply: Utilizing an Astable Multivibrator Circuit
  • Thread starter Thread starter Crazymechanic
The discussion revolves around the feasibility of designing a simple switch-mode power supply (SMPS) using an astable multivibrator circuit powered by approximately 325V DC from rectified mains. Participants explore the potential for generating a square wave to drive MOSFETs for transformer operation, focusing on the absence of integrated circuits and the challenges faced in simulations.
  • One participant questions the practicality of using an astable multivibrator with high voltage, seeking confirmation on whether it can produce a suitable square wave for MOSFET operation.
  • Another participant affirms the possibility but emphasizes that it depends on factors such as operating frequency and current output requirements, suggesting alternatives like high voltage MOSFETs or SCRs.
  • A different participant inquires about the circuit's functionality with certain components removed, pointing out potential issues with reverse overvoltage protection.
  • One participant mentions starting with lower voltages (around 12V) for initial testing, indicating prior successful simulations with specific transistors.
  • Another participant expresses uncertainty about the efficiency and stability of the proposed design compared to using dedicated ICs, while highlighting the importance of careful component selection and safety precautions when dealing with high voltages.
Participants express varying degrees of optimism about the feasibility of the proposed design, with some agreeing on the potential for success while others raise concerns about efficiency and safety. No consensus is reached regarding the best approach or the reliability of the circuit.
Participants note the limitations of simulation tools and the potential discrepancies between simulated and real-world performance. There are also concerns regarding the safety of working with high voltages and the need for proper protective measures.
This discussion may be useful for hobbyists and engineers interested in DIY electronics, particularly those exploring power supply design and astable multivibrator circuits.
Crazymechanic
Hi I would like to know is it reasonable to make a astable multivibrator that is fed from about 325v dc , the rectified +filtered mains.?
I understand that with the right transistors and resistors I will get some oscillation but the question is will i be able to get a nice square wave to drive some mosfets that would then drive a transformer primary?
The idea is of a as simple as possible smps power supply not using any ic's or chips.
So yes the question is can such an arrangement work efficiently and smoothly enough for it to be called a reasonable smps?
I have done very much simulation before finalizing my schematic on multisim but the program is kinda weird sometimes as when I had one circuit with all the transistors and so and it worked very good the simulation showed a nice square wave. I had potentiometers set as reostats in the "r2" "r3" places so that I could tune in for the best performance.Now I calculated the resistance set on those potentiometers and made a new design with all the same just usual resistors in those places and the circuit didn't function at all even changing values was no luck.
Short answer: Yes
It depends on a number of factors, however. What frequency do you want to operate at? How much current output do you need?
While there are high voltage transistors you might be better off using high voltage mosfets, tubes, SCRs, or even electro-mechanical relays.
does it run with R2 and R3 removed?
There's no reverse overvoltage protection for your E-B junctions,,,
but i don't know anything about multisim.
Get one running at ~6 volts with 2N3904's for proof of principle...
well i start with getting one working with about 12 volts and yes with the 2n3904 as I already tried simulations with them in Multisim.
But the main idea stays the same building this simple multivibrator with robust high voltage transistors and feed it directly from the rectified mains then creating a square wave that would drive some mosfets ofcorse I'll include some protection.
I cannot provide a definitive answer without conducting my own experiments and simulations. However, based on my knowledge of astable multivibrator circuits and SMPS power supplies, it is possible to use an astable multivibrator circuit to drive a transformer primary and create a simple SMPS power supply. This approach may not be as efficient or stable as using dedicated ICs or chips, but it can still be a viable option for a DIY project.
It is important to carefully select the appropriate transistors and resistors for this circuit to ensure proper oscillation and square wave output. The potentiometers used in the simulation may not accurately represent the behavior of fixed resistors, so it is important to carefully calculate and choose the appropriate values for the resistors in the circuit.
Additionally, it is important to consider safety precautions when working with high voltages, such as the 325V DC from the rectified mains. Proper insulation and grounding should be implemented to prevent any potential hazards.
Overall, while it is possible to design a simple SMPS power supply using an astable multivibrator circuit, it may require some trial and error and careful selection of components to achieve desired results. It is always recommended to thoroughly test and evaluate any DIY project before implementing it in a real-world application.
  • · Replies 23 ·
  • · Replies 52 ·
  • · Replies 28 ·
