Photon Flux per Unit Wavelength
The discussion focuses on measuring photon flux per unit wavelength for solar radiation. The process involves using a narrow slit and a prism to split light into a spectrum, with sensitive elements capturing specific frequency ranges. Calibration of the setup is essential for accurate frequency and intensity measurements. Filters can restrict solar radiation to specific ranges, such as "400-800nm," rather than a single wavelength.
  • Understanding of photon flux measurement techniques
  • Knowledge of optical components like prisms and slits
  • Familiarity with calibration methods for spectrometry
  • Basic concepts of wavelength filtering and spectral analysis
  • Research methods for calibrating spectrometers
  • Explore the use of optical filters in wavelength selection
  • Learn about the principles of spectrometry and light dispersion
  • Investigate the characteristics of photon flux measurement in solar radiation
Researchers in photonics, optical engineers, and environmental scientists interested in solar radiation analysis and spectral measurement techniques.
QwertyXP
Hi
How do you get a photon flux per unit wavelength curve for solar radiation? My understanding of "per unit wavelength" is that the wavelengths within a very short range are fired at a detector. The range is then gradually changed to cover higher wavelengths. The values of flux measured by the detector are divided by the size of range.
1) Is this how it works?
2) Also, how do you restrict the solar radiation to lie within a specific "range"? Wouldn't a filter only allow photons of a single wavelength, not range of wavelengths.
Thank you.
The usual way to measure a spectrum:
Use a narrow slit and a prism afterwards to split the light into a spectrum. Place a line of sensitive elements after the prism, so each pixel receives to some specific, narrow frequency range. Use some method to calibrate the whole setup (frequency and intensity).
Filters always have some frequency range. This can be something like "400-800nm", or "534.4-534.5nm", or whatever, depending on the requirements.
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 31 ·
