How does a photovoltaic cell convert light into electricity?
The photovoltaic cell operates as a p-n junction diode, formed by doping a semiconductor with V group elements (electron donors) on one side and III group elements (electron acceptors) on the other. This configuration creates a depletion layer where electrons diffuse from the n side to the p side, establishing an electrostatic field and a built-in voltage. When a photon with energy exceeding the bandgap is absorbed, it promotes an electron to the conduction band, generating a hole. The movement of the electron and hole towards their respective sides creates an electromotive force (EMF) when a circuit is completed.
  • Understanding of semiconductor physics, specifically p-n junctions
  • Knowledge of doping elements in semiconductor materials
  • Familiarity with concepts of electron mobility and electrostatic fields
  • Basic principles of electromotive force (EMF) in electrical circuits
  • Research the properties of silicon as a semiconductor material
  • Explore the process of doping in semiconductor fabrication
  • Learn about the bandgap energy of various semiconductor materials
  • Investigate the efficiency factors affecting photovoltaic cell performance
Students, engineers, and researchers interested in renewable energy technologies, particularly those focusing on solar energy and photovoltaic systems.
elpitu1974
i'm very interested in learning about photovoltaic cells, I've read in some sites already but they all describe it in very general way, can anyone tell me on detail how does it work?
thanks
the simplest solar cell is a p-n junction diode sandwiched between 2 electrodes. a p-n junction is most easily created by a single piece of semiconductor doped with V group elements (electron donors) on one side and III group elements (electron acceptors) on the other. the purpose of the p-n junction is to introduce different charge carriers on either side. note that the piece of silicon after doping is still neutral as we are adding neutral atoms to both sides.
in a p-n junction, electrons near the junction start to diffuse from the n side to the p side due to the difference in chemical potential of electrons. however this creates an electrostatic field near the junction that will end the diffusion. the excess electrons in the conduction band on the n side diffusing away into the p side results in a positive charge on the n side and a negative charge on the p side. the region that shows diffusion is called the depletion layer. the voltage associated with this electrostatic field is called the built in voltage. far away from the junction, of course, the material is unaffected.
a photon with energy greater than the bandgap of the material is absorbed by an electron in the valence band. the electron is promoted to the conduction band and leaves behind a hole that acts as an effective positive charge.
due to the built in voltage the electron migrates towards the N side of the depletion layer. the hole migrates towards the P side of the depletion layer. this serves as the EMF once the circuit is completed and an external load is attached.
was this helpful?
