What is the upper limit of magnetic density?
The upper limit of magnetic density is theoretically limitless, contingent upon the availability of resources and equipment. Current capabilities allow for the generation of strong magnetic fields, particularly through methods such as microsecond explosive magnetic fields and electromagnetic pulses (EMPs). These methods can produce high-density magnetic fields, but they remain significantly weaker than those found on a cosmological scale. It is established that magnetic fields cannot transform gases into solid objects or liquids under pressure.
  • Understanding of electromagnetic fields and their properties
  • Familiarity with explosive magnetic field generation techniques
  • Knowledge of electromagnetic pulse (EMP) technology
  • Basic concepts of gas behavior under pressure
  • Research the principles of electromagnetic fields and their applications
  • Explore the technology behind EMP weapons and their effects
  • Study the generation of magnetic fields through explosive methods
  • Investigate the behavior of gases under varying pressure conditions
Physicists, engineers, and researchers interested in electromagnetic theory, as well as professionals working with high-density magnetic fields and EMP technology.
Low-Q
Is it an upper limit of megnetic density? Can magnetic density be so strong it turns "solid"?
Vidar
Well actually a simple google search turned up some answer that might interest you, although I hope you searched yourself before asking?
http://van.physics.illinois.edu/qa/listing.php?id=2635
So basically summing up what the article says, theoretically there are no limits in real life assuming we don't have limited resources and equipment like we have , we could make extremely strong fields , but in the reality with our current capability I would say the upper limit is as the article mentions the one you can achieve with a microsecond explosive type magnetic field.
Look up the EMP , there is a weapon designed specifically to make as strong as possible electromagnetic field for enemy electrical equipment damage also a nuclear detonation makes a very strong magnetic field in a pulsed way.These fields have a high density , yet not even close to the ones on a cosmological scale.
What do you mean by turning solid? Like air or different types of gas, when under high pressure they turn liquid? If so then no I don't think a field of any kind, electric , magnetic can turn into a solid object or even liquid, haven't heard nor seen anything like that happening.
  • · Replies 24 ·
  • · Replies 31 ·
