Electric Fields of straight wire
The discussion revolves around calculating the electric field produced by a long, straight wire with a specified charge per unit length. Participants are examining the relationship between the electric field magnitude and the distance from the wire.
  • Mathematical reasoning, Assumption checking
  • Participants are discussing the application of the formula for electric fields, questioning the representation of variables such as lambda and the value of epsilon nought. There are attempts to manipulate the equation to isolate the distance variable.
Some participants have provided guidance on the equation setup and variable representation, while others are exploring potential calculation errors and clarifying assumptions about constants. There is an ongoing examination of the values used in calculations, but no consensus has been reached on the correct approach or final answer.
Participants are navigating discrepancies in the value of epsilon nought and its implications for the calculations. There is mention of an additive constant affecting the results, indicating potential issues with the setup or interpretation of the problem.
stylez03
A very long, straight wire has charge per unit length 1.47×10^10
At what distance from the wire is the electric field magnitude equal to 2.57 N/C
E = lambda / (2*pi*E_o*r)
E_o = 8.85*10^-9
2*pi*E_o*E / lambda = r
Is this correct so far?
Looks fine you just need to plug the numbers in.
r = 2*pi*(8.85*10^-9)*(2.57) / (1.47*10^-10)
I'm not sure if lambda is represented correctly and is E just 2.57 or should it be 10^(something)
E will just be 2.57 as stated in the problem. Why are you worried about lambda?
I wasn't sure if lambda = 1.47*10^-10
probably more likely to be x10-10 than the other way round.
Thats what I had before 1.47 x 10^-10
What is it in the question?
The original question was if lambda = 1.47 x 10^-10.
You said yes, so I just wanted to make sure.
2*pi*(8.85*10^-9)*(2.57) / (1.47*10^-10) = r
This evaluated to:
r = 972
The online program says I'm off by an additive constant??
I've just noticed you have E on top of the fraction and lambda below. You need to swap these two so the equation is:
[tex]r=\frac{2k\lambda}{E}[/tex]
Like I said in a previous thread, try manipulating equations with just their symbols until the very last moment. Its a lot easier to spot problems that way.
EDIT: Sorry [tex]k=\frac{1}{4\pi \epsilon_0}[/tex]
2* (1/4*pi* 8.85*10^-9) * (1.47*10^-10) / 2.57
= 1.03×10−3
Still says I'm off by a additive constant.
I think you've made a mistake in the calculation as i get a different answer. Try it again you're 3 orders of magnitude out.
Where did you get that value of epsilon nought from? It should be: 8.85x10-12
I need to be more careful from paper to online input. I have so much scratch work, some how I changed the epsilon value =[
  • · Replies 18 ·
  • · Replies 21 ·
