A massless, frictionless pulley is suspended from a rigid rod
A massless, frictionless pulley system consists of two masses, m (50 kg) and M (60 kg), suspended on either side of the pulley by a light, inextendable cord. The net force acting on the system is expressed as Mg - mg = (m + M)a, leading to the conclusion that the acceleration of mass m is (M - m)g/(M + m) upward, while mass M experiences the same magnitude of acceleration downward. The direction of acceleration is determined by the defined coordinate system, where positive is defined as upward.
  • Understanding of Newton's Second Law of Motion
  • Basic knowledge of force diagrams and free-body diagrams
  • Familiarity with concepts of mass and gravitational force
  • Ability to define coordinate systems in physics problems
  • Study the applications of Newton's Laws in various mechanical systems
  • Learn about tension in strings and its effects in pulley systems
  • Explore advanced topics in dynamics, such as non-inertial reference frames
  • Investigate the effects of friction in pulley systems and how it alters acceleration
Physics students, educators, and anyone interested in understanding dynamics and mechanical systems involving pulleys and forces.
Soaring Crane
A massless, frictionless pulley is suspended from a rigid rod. Two masses, m (50 kg) and M (60 kg), are suspended on either side of the pulley, respectively, by a light, inextendable cord. Determine the accelerations of the masses.
I drew the force diagrams of both; there is an upward tension force and a downward gravity force in each. Mg - mg = (m + M)a. Now acceleration of block m is (M - m)g/(M + m) upward and block M's acceleration is the same but downward. So does m have a positive acceleration while M has a negative acceleration?
Thanks.
Could be either, it depends upon how you define your coordinate system. Is positive up or down?
I guess I define positive as going up on the coordinate sys. In the problem, m is pulled up while M goes down.
  • · Replies 31 ·
  • · Replies 16 ·
  • · Replies 19 ·
16K
