Removing Labels from Glass: A Production and Layout II Challenge
  • Thread starter Thread starter SkepticJ
    Challenge Glass
The discussion revolves around the challenge of removing labels from POM glass bottles for a fictional product presentation in a Production and Layout II class. Participants explore various methods and materials to effectively remove the labels without damaging the glass, sharing personal experiences and suggestions.
  • One participant struggles to remove a label from a glass bottle and seeks advice on methods that won't damage the glass.
  • Some participants suggest using solvents like methanol, acetone, and ethanol to remove glued-on labels, while others recommend scraping techniques with hot water and razor blades.
  • Another participant proposes using dichloromethane as a potential solution.
  • One participant speculates that the label may be an epoxy printing ink, suggesting that aggressive chemical methods like aqua regia or strong peroxide solutions could be effective but risky.
  • A participant shares findings from another forum indicating that the label is likely screen printed and fired onto the glass, making it difficult to remove.
  • Some participants recount their attempts to remove the label using various methods, including scraping with utility knives and using nail files, with mixed results.
  • One participant mentions a cleaning solution called Star San, which reportedly can remove the label after soaking for a couple of days.
  • A later reply confirms successful removal of the label using Star San after a specific soaking period.
  • Another participant shares their experience of sandblasting the label off, which resulted in a frosted glass finish that they found desirable for their project.
  • Questions arise about the nature of Star San and how to sandblast items effectively.
Participants present multiple competing views and methods for label removal, with no consensus on a single effective approach. Various techniques are discussed, and personal experiences vary widely.
Some methods suggested may depend on the specific type of label and its adhesion properties, which are not fully understood by all participants. The effectiveness of certain solvents and techniques may vary based on individual circumstances.
This discussion may be of interest to individuals looking for practical solutions for label removal from glass containers, particularly in creative or DIY projects.
SkepticJ
For my Production and Layout II class I need to come up with a a fictional product I'm trying to sell in the ad. Getting to the point, I want to use a http://pomwonderful.com/pomTeaHome.html" glass as my container, but try as I might, I can't get the lable off the glass. Even with my Dremel set to full power. I don't want to use the carbide bits, I know they'll get it off, but they'll damage the glass. I have no clue what the lable is made of, never seen anything else like it. Tough, tough stuff, whatever it is. Any idea of how I can get it off without damaging the glass?
Wasn't sure which sub-forum to put this one under, if it's the wrong place, please feel free to move it.
Chemistry news on Phys.org
Is the "glass" actually made of glass? Have you tried a sand/bead blaster? Have to tried a dip in methanol and acetone?
Is the label glued on or painted on? To remove most glued-on labels, I get off as much as possible with an initial soak in hot water and scraping with a razor blade, then alcohol. Gokul suggested methanol, but ethanol also works on most labels...I've never tried isopropanol (rubbing alcohol), but that is usually more readily available to the average student. A good steel wool scrubbing usually takes the rest off (as long as it's glass...plastic will get scratched by steel wool). As Gokul suggested, acetone may also work if the label is painted on or has a plastic coating resistant to other solvents. In case you didn't know, a good source of that is regular nail polish remover. That will destroy a lot of plastics, so be careful where and how you use it.
If none of that works, or has already been tried, let us know what else you've already tried and as much as you can about the label itself (it's hard to tell from the photo).
If you have access to it, also try some dichloromethane. It is used in paint thinners so it might help take it off.
I would really appreciate if you could let me know whether you've found a way to remove the POM label. I love the drink and have lots of the bottles hanging around and would hate to waste them! Thanks so much!
Thanks for the suggestions, guys. I've picked up a few of the suggested solvents. Yet to try them out though. I'll report the results.
The label is probably an epoxy printing ink. Good luck getting it off without marking the glass.
If it were me, I would use aqua regia and a good hood or a strong peroxide and base like NaOH and 30% H2O2 (piranah etch).
I did some internet research and found this comment on another forum:
The last system used is ACL (Applied Color Label), and it isn't likely you will get this off. The color is screen printed onto the glass by the decorator before it even gets to the distillery and then fired on. Some of the colors are ceramic and some are organic. Most if not all at BT are ceramic now, but they are working on switching to organic for Rain. I have never tried but you might be able to scrape the organic colors off with an Xacto knife because they are not quite as hard as the ceramic, but I doubt it.
Personally, I've been trying a few methods to get those POM labels off. I tried using the utility knife to scrape it off, but that doesn't really work. I use alcohol, but there was no change. My friends took a lighter and tried to somehow burn the label off, but all they did was make the glass all black, and the label dirty. I put some super glue on the label, then tried to scrape it off, in hopes that it'll somehow lift the label stuff off.
The only relative success I've had is from using a nail file (I assume some fine grained sand paper will also work) to rub the label off. The remaining area is kind of "blurred" or "smokey."
I found your post while i was researching the same exact thing myself (removing the pom label)
Apparently the people brewing their own beer had a solution that got rid of the ACL labels but i don't know how well it works (havent tried it myself yet was waiting on getting some feedback from them)
But apparently a cleaning solution called Star San works. If you let it sit a couple days in that it will eat off the label. Though it either has to dry for it to come off, or just fall off like rust depending on comments of people.
I figured I'd mention it if you still needed the info
Test completed. 2 days (about 46 hours) 1 oz of Star san, 2.3 gallons of water.
result: upon rubbing down the Pom Tea bottle with a few paper towels, No label remained, nothing on it at all.
Interesting, thanks.:smile: I ended up just sandblasting the label off. That frosted the glass quite nicely, but that ended up being what I actually wanted for the fictional beverage product.
What is star San? I want to make a hookah out of one of the large POM bottles, and having no labels would be awesome.
Also, How does one get random items sandblasted?
  • · Replies 20 ·
  • · Replies 19 ·
