Which filtration method is best for volatile solvents?
  • Thread starter Thread starter kuahji
    Gravity Vacuum
The discussion revolves around the comparison of filtration methods for volatile solvents, specifically examining the advantages and disadvantages of gravity filtration versus vacuum filtration. Participants explore the contexts in which each method is preferable, considering factors such as particle size, boiling point of solvents, and the nature of the substances being filtered.
  • One participant notes that gravity filtration is effective for larger particles and low boiling point solvents, suggesting it is safer for hot solutions and minimizes the risk of solvent evaporation.
  • Another participant mentions that vacuum filtration is advantageous for filtering very small particles and can facilitate quicker drying of crystals, although it may not be suitable for volatile solvents due to the risk of evaporation.
  • A different viewpoint suggests that vacuum filtration can still be performed under gravity and may work with nonflammable solvents, indicating a potential overlap in methods.
  • Concerns are raised about using vacuum filtration with volatile solvents, as it may lead to contamination of solid samples through evaporation.
Participants express differing opinions on the suitability of vacuum filtration for volatile solvents, with some arguing against its use in such cases while others suggest it can be effective under certain conditions. The discussion remains unresolved regarding the best practices for filtering volatile solvents.
Participants reference specific conditions such as solvent boiling points and particle sizes, but there is no consensus on the optimal filtration method for volatile solvents, highlighting the complexity of the topic.
kuahji
Just wondering if there was a website or something where I could get more information on the subjects. I understand the methods of procedure, just not the why would one method be used over the other. So, any help or links would be appreciated. :smile:
Chemistry news on Phys.org
In my own experience, gravity filtration is used for filtering largers size particles through media that is fairly coarse (if you consider #2 Whatman coarse). You can look up the micron size in a chemical supply catalog like the VWR or Fisher catalog. Gravity filtration is also best used when the solvent has a low boiling point such as ether or hexane or when the solution is hot. Pulling a vacuum on hot solutions, especially flammable ones, can cause all kinds of problems. I have also seen vacuum filtration not filter small particles where a gravity filtration works fine. Apparently, vacuum can force some near pore size solids through the filter media where gravity filtration wouldn't. It is easier to quantitatively recover something from a gravity filtration in most cases. Gravity filtration is more useful for filtering gel type substances like nickel DMG.
Vacuum filtration is usually performed with a filter aid such as diatomite. The real advantage for the filter aid/vacuum filtration is in the filtration of very small particles such as decolorizing carbon. Air can be drawn through the filter cake to minimize losses and solvent can be easily applied to rinse a valuable solid. Gravity filtration is not as useful for rinsing crystals, for example, because the rinse solvent would be in contact with the product longer and result in greater losses. Vacuum filtration can be used to dry crystals quickly to speed their analysis. Gravity filtration would require a more lengthy drying step either in the hood or in an oven (or drying thimble).
Vacuum filtration is useful if you are in a hurry but if you don't want to tie yourself up monitoring a filtration, gravity filtration can give you time to do other tasks.
Hope it helps.
use both together - simple vacuum filtration is done still under gravity. check your sizes as chemisttree says.
PS vacuum caused by nonflammable solvents will work (try water). Dichloromethane as solvent will work
well.
reason:
Vacuum filtration is most suitable for nonvolatile solvents. If vacuum filtration is used with volatile solvent than the solvent might evaporate and contaminate your solid sample.
  • · Replies 24 ·
  • · Replies 19 ·
  • · Replies 32 ·
