olgranpappy said:
Is an entangled state always a pure state?
I am not familiar with quantum entanglement of mixed states (William probably is), but there is a definition in this case as well, and it seems to be what I would expect. Scroll down to the Ensembles section from the wikipedia link given by Marcus in post #6.
...furthermore, that state is nothing more that the usual state of total spin 1 and z-projection 0. Similarly the other independent linear combination (the |0,0> state) is also what you would call an "entangled" state, but I would simply call them "states with S_z=0."
In the example I chose, the state spaces are irreducible representation spaces of the (cover of) the rotation group. The product representation space is not irreducible, but can written as a direct sum of irreducible representation, i.e.,
[tex]D_{1/2} \otimes D_{1/2} = D_0 \oplus D_1[/tex].
I just happened to chose a state in [itex]D_1[/itex], but I didn't have to do this. I could have chosen
[tex]\left| \Psi \right> = \frac{1}{\sqrt{2}} \left| \uparrow \right> \left| \uparrow \right> + \frac{1}{2} \left| \uparrow \right> \left| \downarrow \right> - \frac{1}{2} \left| \downarrow \right> \left| \uparrow \right>,[/tex]
which, if I have done things correctly, is an entangled state that is a linear comnination of states from [itex]D_1[/itex] and [itex]D_0.[/itex]
The state [itex]| \Psi >[/itex] is entangled ecause it cannot be written in the form [itex]| \psi > | \phi >.[/itex]
Apparently there is no difference, except that you have invented some new language that seems to serve no purpose.
Entanglement has nothing to with angular momentum per se, and so can't, in general, be described by the language of angular momentum. Although my example involved angular momentum, the original definition of entanglement that I gave did not involve angular momentum. The original EPR example did not involve angular momentum. The example using spins was popularized, I think, by David Bohm.
I didn't invent the language, so I would prefer that you say "except that new language has been invented that ..."
I don't know when the term "entangled" came into use either in research or in texts. I have a text published in 1986 that I thought used the term, but upon checking I find that although it discusses entangled states, it doesn't call them entangled states. I do have a 1995 "text" that uses the term extensively.
In my opinion, the language does serve a useful purpose. Quantum entanglement is used in stuff like quantum teleportation and quantum cryptography, and is involved in a substantial amount of quantum "weirdness".
