Torque calculation, is this correct?
  • Thread starter Thread starter WhiteHawk
    Calculation Torque
The discussion centers on torque calculations involving a torque arm of 15 inches exerting a force of 6000 lbs, resulting in a torque of 7500 ft-lbs. To counter this torque with a shorter arm of 5 inches, the required opposing force was calculated to be 18000 lbs. This calculation is confirmed as valid, as a shorter moment arm necessitates a proportionally greater force to achieve equivalent torque. The conclusion emphasizes the relationship between moment arm length and required force in torque applications.
  • Understanding of torque and its calculation
  • Familiarity with units of measurement (inches, pounds, foot-pounds)
  • Basic principles of mechanics and force
  • Knowledge of moment arms and their impact on torque
  • Research the principles of torque and moment arms in mechanical systems
  • Learn about the calculations involved in brake force requirements
  • Explore the effects of different moment arm lengths on torque generation
  • Investigate practical applications of torque calculations in automotive engineering
Mechanical engineers, automotive technicians, and anyone involved in designing or analyzing braking systems and torque applications in vehicles.
WhiteHawk
I'm experimenting some ideas and needed a verification of my formula.
There is a torque arm of 15" with a force of 6000 lbs perpendicular to the axis of rotation. So that calculates to 7500 ft/lbs (6000*15/12). So on the same axis, there is a torque arm of 5" the must oppose this force equally, I need that force required. I calculated 18000 lbs of opposing force with 7500 ft/lbs at the axis (7500/5*12).
Is this valid?
No its not a homework question :) I need to know how powerful a single disc brake on a truck is.
Thanks in advance.
Yes. If you have 1/3 of the moment arm, you need 3 times the force to give the same torque.
Thanks!
  • · Replies 18 ·
  • · Replies 44 ·
