Spectrometer vernier scale. Quick answer
  • Context: Undergrad
  • Thread starter Thread starter teleport
    Scale Spectrometer
The discussion revolves around the use of a spectrometer's vernier scale for measuring emission spectra, specifically focusing on the angle measurements and the necessary corrections when discrepancies arise between the readings from the left and right sides of the scale.
  • Experimental/applied
  • One participant questions how to correct angle measurements that differ by more than 180 degrees, noting that the left side readings are close to 360 degrees while the right side readings range from 20 to 60 degrees.
  • Another participant inquires about the reference "0 degree" position in the diffraction formula, suggesting that knowledge of the zeroth order angle is necessary.
  • Some participants recall that the zeroth order might be at 180 degrees, but there is uncertainty about whether this is standard practice.
  • A participant reflects on past experiences where students inconsistently recorded data from two vernier scales, leading to potential inaccuracies, and emphasizes the importance of checking calibration.
  • Another participant suggests that measuring on both sides of the spectrometer is crucial to account for possible misalignments in the instrument or diffraction grating.
  • One participant expresses confusion over the large angle obtained when averaging the readings from both sides and seeks clarification on the appropriate correction method.
  • There is a proposal to adjust the angle using a specific formula, but confirmation of this method is requested.
  • A participant explains that in certain spectrometers, one scale's reading should be reduced by 180 degrees to ensure consistency before averaging the two readings.
Participants express varying levels of understanding regarding the calibration and correction of angle measurements, with no consensus on the exact method to apply for corrections. Multiple competing views on the zeroth order position and the necessity of using both scales remain unresolved.
Participants mention the potential for misalignment in the spectrometer setup, which could affect the accuracy of angle measurements. There is also uncertainty regarding the standard practices for determining the zeroth order angle and how to apply corrections based on the readings from both sides of the scale.
teleport
Spectrometer vernier scale. Quick answer please!
This is a quick question. I am measuring the emission spectra for hydrogen, but now I'm finding myself wondering about measurements in the vernier scale. I have the right and left angle measurements; however they differ by more than 180 degrees. The ones on the left side are cloe to 360, while the ones on the right side are from 20 to 60 degrees. To make the angle correction what would I need to substract to what? Thanks
In the diffraction formula, where are these angles measured from? There is a position that is the reference "0 degree" position.
Hint: you will need to know the angular position of the zero'th order.
Zz.
I get it, but I don't have the scale in front of me right now. Is the zero'th order just 360 degrees (is this regular?)?
Now I vaguely remember the TA said something about 180 degrees. Could it be this is the position of the zero'th order? i.e. is that regular?
Despite the title of your question, it doesn't sound like you're asking about the vernier scale specifically.
In the past I've demonstrated a diffraction spectrometer lab in which the apparatus happened to have *two* (vernier, incidentally) scales, one on each side. Frequently students made the mistake of inconsistently recording some data from one scale, and some data from the *other* scale. This sounds like your problem.
I told those students that they should redo the experiment for accuracy, but it did turn out that the scales happened to be calibrated "almost exactly" 180 degrees apart. If something like that is the case, anybody can figure out how to roughly correct their original data simply by drawing a diagram of the experiment from above (a circle with the 360 degrees of markings, the grating in the middle, coloured lines for each ray..), but to do so without checking the calibration yourself is effectively falsifying data. (I just hope you learn the lesson, which is to keep a much better log book, and think before you do the experiment. Then ask the necessary questions when the assistant/demonstrator arrives.)
Hmm, I remeber this very well. It was mentioned in the lab, but I'm almost 100% sure I used only one of the two scales. I don't think that is my problem. This is because the TA mentioned we would have to make the correction for the angle, assuming we had not made the error you mention. It is probably just what ZZ mentioned, but I do not recall the zeroth. This is my problem.
I do not know what kind of a spectrometer you are given, so I have no idea how the scales are oriented.
In experiments like this, there is a good reason why you are asked to measure on both sides. Just think, you actually need just the position on ONE side, in principle to get the value of the frequency or wavelength. So why are they making you measure both sides? This is because there could have been some error in the positioning of the instrument, in the positioning of the diffraction grating, etc... that many not properly align the interference lines with the scale on the instrument. What I mean here is that if the dead center of the instrument is, let's say, 0 degrees, a slight misalignment could cause the 0th order to be at, say, 3 degrees to the left.
So we tend to ask the students to measure both sides, take the difference, and divide by two. Hopefully, if there's any misalignment, the error for this can be minimized. Alternatively, one can also figure out where the zeroth order is, and subtract (or add) the off-zero value to all the values being measured. That would produce more or less the same result.
Zz.
Yes, however, I have degrees like 356 on the left side, and 25 on the other side, both for the same line on order 1. When I subtract them and divide by 2 it gives me the angle 165 which is huge for order 1. So I probably need to make some adjustment to the angle. What correction is that?
Is it just (25 + 360 - 356)/2 ? Makes sense to me. Confirmation?
If this is like the Pasco spectrometers that we use, those two scales are for reducing or eliminating error due to eccentricity in the bearings that the scales rotate on. You're supposed to read both scales, reduce one reading by 180 degrees to make them consistent, then find the average of the two readings. Usually they differ by at most a few minutes of arc after reducing one of them.
Then, if you're using a diffraction grating rather than a prism, you're supposed to repeat this procedure for the same line as it appears on both sides of the central axis, and find the average of the (absolute value of) the two diffraction angles, measured from the central axis.
