How Does Delta S Relate to Proper Time in Special Relativity?
  • Thread starter Thread starter nwdavis1
    Proper time Time
The discussion focuses on demonstrating that when the spacetime interval (ΔS)² is greater than zero, the proper time (τ) between two events can be expressed as τ = ΔS/c. Participants clarify that the proper time is defined as the time measured in the frame where the two events occur at the same spatial location (Δx = 0). The solution involves substituting this definition into the spacetime invariant equation, confirming that this relationship holds true for events where (ΔS)² ≥ 0.
  • Understanding of spacetime intervals in special relativity
  • Familiarity with Lorentz transformations and their equations
  • Knowledge of the concept of proper time in physics
  • Basic grasp of the speed of light (c) as a constant
  • Study the derivation of Lorentz transformations in detail
  • Explore the implications of spacetime intervals in different reference frames
  • Learn about the concept of simultaneity in special relativity
  • Investigate the relationship between proper time and time dilation
Students of physics, particularly those studying special relativity, educators teaching advanced physics concepts, and anyone interested in the mathematical foundations of spacetime and proper time.
nwdavis1
If the spacetime interval (delta S)^2 > 0, show that delta t=deltaS/c is the proper time between the two events.
Can anyone please explain to me how I should be approaching this problem. I have been working on it for a while with no success. I was able to do the problem before it easily, which was "use Lorentz' equations to prove that delta S is invariant", but this one is giving me trouble.
I guess I worded the problem incorrectly. It should read "for ds^2 >0, show that tau=ds/c is the proper time".
By definition, th eproper time is the time between two events in the frame where the two events occur at the same position. So all you have to say is that when you are in the frame where [itex]\Delta x =0[/itex] then [itex]\Delta t = \tau[/itex]. Plug that in the spacetime invariant and you get the answer. Note that this definition works only for events for which [itex](\Delta s)^2 \geq 0[/itex].
  • · Replies 31 ·
