Capacitor Charge and Voltage Distribution in a Circuit with Multiple Capacitors
The discussion focuses on the behavior of capacitors C_1, C_2, and C_3 in a circuit after a switch is flipped, transitioning from an initial state where C_1 is charged to 100V with 1.5 mC of charge. The equivalent capacitance of C_2 and C_3 is determined to be 12 µF. The participants conclude that while C_1 initially influences the circuit by providing current, its effect diminishes as the system stabilizes, leading to a steady state for C_2 and C_3. Kirchhoff's rules are recommended for analyzing the circuit's voltage distribution post-switch flip.
  • Understanding of capacitor behavior and charge distribution
  • Familiarity with Kirchhoff's circuit laws
  • Knowledge of equivalent capacitance calculations
  • Basic concepts of voltage and current in electrical circuits
  • Study Kirchhoff's Voltage Law (KVL) in detail
  • Learn about transient analysis in RC circuits
  • Explore equivalent capacitance in series and parallel configurations
  • Investigate the effects of capacitor charging and discharging on circuit behavior
Students studying electrical engineering, circuit designers, and anyone interested in understanding capacitor dynamics in electrical circuits.
awvvu
http://img512.imageshack.us/img512/6864/59797183jd5.png
(capacitance in micro farads).
Initially the switch is at the left position and capacitors C_2 and C_3 are uncharged. Then the switch is flipped to the right position. Afterward, what are the chard on and the potential difference across each capacitor?
First I turned C_2 and C_3 into a capacitor with equivalent capacitance 12 uF.
Before the switch flip, C_1 is charged to 100V and has 1.5 mC of charge. I'm not sure what happens after the switch flips though. Does C_1 still affect the circuit? If not, then its charge and voltage won't change from before it flipped. And then the voltage and charge on C_2 and C_3 are completely unaffected by the presence of C_1?
Since the switch is flipped to the right, the circuit loop doesn't connect to both terminals of the battery, so what you could do is ignore the battery in the system. I'm thinking that C1 does affect the other 2 capacitors, in which it provides a current to the capacitors for a short interval of time. At some point, the current should approach 0 effectively enough and the capacitors should approach some steady charge and voltage. What you could use is Kirchoff's rules for the particular loop of C1, C2, and C3, in which you come up with an arbitrary current and set the net voltage along the loop to 0V.
Oh I didn't even notice that the battery wouldn't connect to the other two capacitors... doh!
  • · Replies 16 ·
