PMOS Transistor Circuit - Is It Enhancement or Depletion Mode?
The discussion centers on the characteristics of a PMOS transistor in a given circuit, specifically addressing whether the threshold voltage (V_TP) is greater than or less than zero. It concludes that if V_TP is greater than zero, the transistor operates in enhancement mode, while if it is less than zero, it operates in depletion mode. The correct symbol for the PMOS transistor must also be verified against standard representations. The participants emphasize the importance of resistor values in determining V_TP mathematically.
  • Understanding of PMOS transistor operation and characteristics
  • Familiarity with threshold voltage (V_TP) concepts
  • Knowledge of circuit symbols for transistors
  • Basic circuit analysis involving resistors and voltage
  • Study PMOS transistor characteristics and operation modes
  • Learn how to calculate threshold voltage (V_TP) in PMOS circuits
  • Review standard transistor symbols and their correct usage
  • Explore circuit analysis techniques involving resistors and voltage sources
Electrical engineers, electronics students, and anyone involved in circuit design or analysis, particularly those working with PMOS transistors.
opticaltempest
Here is the problem:
The PMOS transistor in the figure is conducting current.
(a) Is V_TP > 0 or V_TP < 0 for this transistor?
(b) Based on the value of V_TP, what type of transistor is in the circuit?
(c) Is the proper symbol used in this circuit for this transistor?
(d) If the symbol is not the correct one, which one should be used?
Here is the circuit:
http://img72.imageshack.us/img72/946/circuitri9.jpg
Here are the transistor symbols from which we must choose:
http://img410.imageshack.us/img410/972/symbolsyf0.jpg
Here are equations corresponding to PMOS transistors:
http://img299.imageshack.us/img299/4448/equationskg7.jpg
I'm a little confused as to how I can determine whether V_TP is greater or less than zero. I think it is going to depend on the values of the resistors. Is it possible to work through this problem mathematically in order to verify this?
Thanks
I would think you could formulate all the answers just from looking at the specs you provided for the transistor. What answers have you came up with so far?
15K
  • · Replies 59 ·
