Short & simple viscosity question
  • Thread starter Thread starter mr-tom
    Short Viscosity
The discussion revolves around the viscosity of glycerol, specifically addressing the potential effects of water evaporation or absorption on its viscosity. Participants explore the relationship between glycerol and water in terms of viscosity changes, with a focus on experimental observations and calculations.
  • Exploratory, Technical explanation, Debate/contested
  • One participant calculated the viscosity of glycerol to be about 1.9 P, which is higher than the expected value of 1.5 P, and questions whether evaporated water could be a factor.
  • Another participant asks for details about the viscosity calculation to better understand the context.
  • A participant suggests conducting an experiment by placing glycerol in a watch glass to observe any changes.
  • Concerns are raised about measurement conditions, including density, temperature, and potential error sources like parallax error.
  • One participant mentions that water can absorb into many substances, including alcohols, and speculates that water may have absorbed into the glycerol, potentially increasing its viscosity.
Participants express uncertainty regarding the behavior of water in relation to glycerol, with no clear consensus on whether water evaporates from or absorbs into glycerol. Multiple viewpoints on the viscosity measurement and its influencing factors remain present.
Limitations include the lack of definitive evidence regarding water's interaction with glycerol and the potential impact of measurement errors on viscosity calculations.
mr-tom
I've managed to calculate the viscosity of glycerol to be about 1.9 P. Google says it's supposed to be 1.5. Could I say that evaporated water has caused the glycerol to become more viscous than it should be? (It could just be a thicker glycerol but I'm just looking things to blab on about)
Basically: Does water evaporate from glycerol and if so does it make it more viscous?
Chemistry news on Phys.org
What's your calculation?
It's abit lengthy and I'm pretty sure it's right, I just need to know whether water evaporates from glycerol if you leave it out without a lid.
Try it- put some in a watch glass, see what happens.
Have you measured the density? What temperature did you do the viscosity measurement at? What are your error sources?
The density was given as 1200 kg m-3, temperature was an average of 21 degrees C. My only error source is parrallax error. But my % error was 10.7%. I can't really try it but I'll mention the watch glass thing in my evaluation, thanks.
Water actually absorbs into most alcohols if the alcohol is left in the air however I'm not quite certain if this the case with glycerol. Water makes a lot of substances more viscous especially if it can hydrogen bond with the other species. In this light water probably absorbed into your glycerol and caused it to become more viscous.
16K
  • · Replies 23 ·
25K
9K
  • · Replies 17 ·
  • · Replies 32 ·
  • · Replies 17 ·
  • · Replies 21 ·
