How to solve this 2nd order nonlinear differential equation
The discussion revolves around solving a second-order nonlinear differential equation of the form y'' + a*y*y' + b*y = 0, where a and b are constants. Participants explore both analytical and numerical methods for solving this equation, as well as a slightly more complex variant that includes a constant term.
  • Homework-related
  • One participant introduces the equation and asks if it can be solved analytically or if numerical methods are recommended.
  • Several participants suggest using the substitution y' = u to reduce the equation to a first-order system of ordinary differential equations (ODEs).
  • There is a discussion about the application of the chain rule to express the second derivative in terms of u and y.
  • Some participants express confusion about specific transformations and the implications of integrating the resulting equations.
  • One participant mentions a specific solution form involving logarithmic terms and questions the feasibility of expressing u in terms of y.
  • Another participant raises a different second-order nonlinear ODE and seeks analytical solutions, indicating a broader interest in similar equations.
  • Additional participants inquire about particular solutions to related equations, with some suggesting perturbation theory for approximations.
  • There are mentions of software tools like wxMaxima and Maple for numerical solutions.
Participants generally agree on the approach of using substitutions to simplify the equations, but there is no consensus on the feasibility of expressing u in terms of y or on the specific solutions to the equations discussed. Some participants express uncertainty about the transformations and their implications.
Some participants note that earlier posts may have contained errors in the conversion of derivatives, which could affect the discussion. There are also indications that some participants may have constructed incorrect equations initially, leading to confusion in the problem-solving process.
This discussion may be useful for students and researchers in mathematics, physics, and engineering who are dealing with nonlinear differential equations and are looking for methods of solution or clarification on specific techniques.
tornado681
Hello all,
This is the first time I've stumbled across this site, but it appears to be extremely helpful. I am a meteorology grad student, and in my research, I have run across the following 2nd order non linear differential equation. It is of the form:
y'' + a*y*y' + b*y=0
Can this equation be solved analytically? If not, what program does one recommend for solving it numerically? There is also a slightly more complex form of this equation:
y'' + a*y*y' + b*y=c
where a, b and c are constants
If anyone could assist me in solving this or direct me to a source for solving it numerically, it would be most appreciated.
Thanks,
--tornado
Try the substitution y' = u to reduce it to a first order system of two ODEs. (Source:Tenenbaum/Pollard)
Ie., your first ODE becomes the system y' = u, uu' = -ayu - by, where in the second eq. u is treated as u(y) and u' = du/dy, which we can then plug into the first equation to integrate for y(x). The second equation is separable, so there is a straightforward analytic solution.
slider,
Im not following you. Could you go into a let more detail if possible. Thanks,
--tornado
Assuming y is function of x, y' = u. u' = d^2y/dx^2 = d/dy (dy/dx) dy/dx by the chain rule. This is equivalent to u du/dy. Hence u' = u du/dy.
After substituting for y' = u, the ODE is u' = -ayu - by. Replacing u' with u du/dy gives:
u du/dy = -y(au+b) This equation is separable and hence solvable. Once you have u(y), you have dy/dx = u(y), which is again separable and solvable.
defennder,
I understand how you get: u' = -ayu - by when you set y'=u
I don't understand how u'=u du/dy . I appreciate you trying to work me through this. Any additional explanation would be appreciated.
Specifcally, how is this so:
--tornado
That follows from the chain rule.
[tex]\frac{d^2y}{dx^2} = \frac{d}{dx} \left ( \frac{dy}{dx} \right ) = \frac{d}{dy} \left ( \frac{dy}{dx} \right ) \ \frac{dy}{dx}[/tex]
Replace [tex]\frac{dy}{dx}[/tex] with u.
When I solve u' = -ayu - by I get:
[tex]\frac{u}{a}-\frac{b}{a^2}ln[|{au+b}|]+C_1 =-\frac{1}{2}y^2 + C_2[/tex]
So then we need to make the above equation u=u(y) correct? Since we have a ln (natural log), is this possible? Any more help is most appreciated. Thanks,
--tornado
anyone care to comment on the solution?
anyone?
--tornado
I don't get that. From du/dy= -y(au+ b) we can get du/(au+b)= -ydy so, integrating both sides, (1/a)ln(au+ b)= -(1/2)y2+ C. I don't know what you mean by "make u= u(y) correct". Solve for u? Without your additional "u/a" that's easy:
[tex]au+ b= C'e^{-\frac{y^2}{2}}[/tex]
where C'= aeC.
where C'= aeC.
Actually u' isn't du/dy.
[tex]u' = \frac{du}{dx} = \frac{du}{dy} (\frac{dy}{dx}) = u \frac{du}{dy}[/tex]
That's where the u/a term comes, once you do long division of u/(au+b).
Defennder,
How do you rewrite u in terms of y only? Can it be done?
Honestly I have no idea if it's possible. It never occurred to me earlier because I didn't actually attempted the DE itself, I just noted it would be solvable if such could be done.
tornado681 said:
Defennder,
Yes, that is a simple application of the chain rule. In fact, that application to differential equations is a standard method called "quadrature"
Actually he was referring to this post:
--tornado
I really don't see how to write u in terms of y there. And anyway the post which resurrected this thread and which preceded yours appears to have been deleted.
Does anyone can help me to solve this second order non linear ODE:
y'' + (2/x)(y') - (1/2y)(y')(y') = K,
y' = dy/dx
y'' = dy'/dx
y = y(x)
I've already guess y=Ax^2 satisty this equation, but I want to solve it analitically..
Please help!
Thank before..
Hi,
I'm trying to solve y''(t) + w02 y(t) = k y(t)2 sin(w t). Does anybody know, how to get a particular solution?
Thanks.
Miriam100 said:
Hi,
Thanks.
There's probably no general analytic expression. At least, wolfram alpha doesn't give one, even when I give it initial conditions.
How large is k supposed to be compared to [itex]\omega_0^2[/itex]? If it's supposed to be small, you could do perturbation theory to get an approximation solution valid when [itex]ky(t) \ll \omega_0^2[/itex].
try (f(x+0) - f(x))/0
divide out the zero
and say tadah, solved numerically. whatever the hell that means.
Thanks for your help. The instructions say 'solve the problem analitically', so I guess I counstructed a wrong equation. It's without y^2, so there's no problem anymore. Tnx.
To recap:
[tex] u \equiv y'[/tex]
Then, the second derivative became:
[tex] y'' = \frac{d y'}{d x} = \frac{d u}{d y} \frac{d y}{d x} = u \frac{d u}{d y}[/tex]
and your equation becomes:
[tex] u u' + a y u + b y = c[/tex]
where [itex]u' \equiv du/dy[/itex]. I think some previous posters made a mistake in converting the second derivative.
Suggest than use the program wxmaxima or maple!
Thanks for advice. However, it turned out that I constructed a wrong differential equation at the beginning. A new one was very simple to solve.
  • · Replies 52 ·
11K
